Author Topic: Thru Hull or Jack Plate Mount Transducer 798ci  (Read 9184 times)
Offline seanrickr
« on: May 18, 2013, 09:37:40 AM »
I seem to always be messing with the transducer to get a proper reading. Was thinking of going with the thru hull transducer or a jack plate mount for current si transducer. I know you have to drill a hole for the thru hull, which I will have a local shop do, but what are pro's and con's of both (besides the "hole").
Re: Thru Hull or Jack Plate Mount Transducer 798ci
« Reply #1 on: May 20, 2013, 12:38:12 PM »
Welcome to the Side Imaging Forums seanrickr!
Jackplate mount: Pro would be that the transducer is more protected from damage.  Con would be that you have to have a second transducer to get higher speed 2D sonar readings, but if this is on a fiberglass boat and XP-9-20 transducer (and AS-Si-DB-Y cable) than you will get the best possible high-speed water depth readings.
Thru-Hull mount: Pro would be that one transducer may be able to provide all of  the Si/Di and 2D sonar readings (if your boat hull will allow for this).  Con would be the cost and that the transducer is exposed to possible damage.
Last post January 23, 2011, 06:46:33 AM
by stillbear
Last post March 13, 2011, 05:47:57 PM
by lolar3288
Last post January 17, 2012, 06:54:23 PM
by stillbear
Last post May 22, 2012, 02:06:46 PM
Last post July 02, 2012, 07:58:46 AM
by bbushong
Last post February 05, 2013, 07:54:30 PM
Last post February 07, 2013, 10:48:02 AM
by fishbone
Last post April 13, 2014, 11:25:37 PM
