Author Topic: Installing SI Transducer on Transom.  (Read 8123 times)
Offline bucketmouth 87
  • Unit(s): 898c hd si
« on: January 26, 2015, 02:42:02 PM »
OK guys i have a 08 Trition Explorer and i want to install my 898 SI on the transom but i cant decide on a location on where to mount it.  Every where i look online seems to show a different location.  I attached a picture of my boat with 3 possible locations.  I have 2 different levels to my hull so im not sure if i install it up on the top or lower step.  Also i do not have a jackplate.  If anyone has any other options for me i would love to hear them. THanks
« Last Edit: January 26, 2015, 05:13:34 PM by bucketmouth 87 »
Re: Installing SI Transducer on Transom.
« Reply #1 on: January 26, 2015, 08:37:39 PM »
Here is Triton installation info ...
http://www.bbcboards.net/humminbird-sonar-gps/241946-triton-installation-images.html
Most fiberglass installations usually opt to mount the HDSI xducer a little higher on the transom for protection ... And then use the AS SIDB Y cable with a "shoot thru" XP 9 20  epoxied in the bilge for high speed depth readings ...
« Last Edit: January 26, 2015, 09:00:59 PM by rnvinc »
« Reply #2 on: January 26, 2015, 11:03:48 PM »
Rickie,
So are you saying mount it to the right of the motor mount and have the middle of the transducer even with the bottom of that rib?
Last post August 03, 2010, 02:15:46 PM
Last post September 01, 2010, 12:37:02 PM
by stoporilshoot
Last post December 17, 2010, 10:50:16 AM
Last post April 16, 2011, 05:05:18 PM
by gofission
Last post July 19, 2012, 11:54:07 AM
Last post November 11, 2012, 12:14:59 AM
by gawnfishin
Last post July 21, 2014, 04:13:30 PM
by TXAG DAC
Last post August 24, 2016, 10:47:56 PM
