Author Topic: SI transducer on deep vee transom  (Read 18247 times)
Offline gofission
  • Unit(s): PiranaMax 160, Matrix 37, 798ci HD SI
« on: April 10, 2011, 08:11:10 PM »
I mounted my 798 ci HD SI transducer on my 23 degree deep vee hull using the manual directions. The inside edge lines up with a staight edge like it should.  I notice that the outside of the TD is way below the hull line. It looks like it will make a heck of a rooster tail. I launch in 6 days. Any thoughts?
Re: SI transducer on deep vee transom
« Reply #1 on: April 11, 2011, 11:54:15 AM »
As always a picture or two would help with the visualization.
You are correct in that it may rooster tail..
Offline Roddy
  • Scan,scan and rescan
« Reply #2 on: April 11, 2011, 10:15:17 PM »
sir; I had to make a top spray cover for one install on a deep V. simple .060 sheet steel 1.5" wider than xducer bent in the shape of an "L". It worked.  :) Enjoy Roddy
Scan,Scan and Rescan Roddy
« Reply #3 on: April 12, 2011, 01:52:20 PM »
If it does than just install the roostertail plug that was packaged with your unit.
On some boats (especially deep-vees) you have to mount the transducer this low.
Offline gofission
« Reply #4 on: April 12, 2011, 06:22:54 PM »
Ok all my stuff is at the shore. Heading down thurs night. I'll take a few pics of the mount. I do not remember seeing a rooster tail plug. Anyone have a pic of this plug?
« Reply #5 on: April 12, 2011, 06:32:30 PM »
Not all units shipped with the plug...
Let me look around the forum.  there was a picture of this a while back...
« Reply #6 on: April 12, 2011, 06:59:35 PM »
Well, I looked for a while and I cant find the picture.
So I went to the humminbird web and searched under tranducer accessories and while they show all the transducer mounting stuff none of the pictures show the rubbber plug.
I did find mention of a yell sheet that comes with a unit that has the ruber plug but could not find any pictures of the yellow sheet or the plug...
Anybody else???????
« Reply #7 on: April 14, 2011, 03:38:05 PM »
I was thinking that all of the 798 units shipped out with the roostertail plug (unless someone did not put it in the box…).  It should have been in a small plastic bag by itself – it’s black and oddly shaped.  I don’t have a picture of it.  I think we stopped the yellow sheet a while back Chuck.
« Reply #8 on: April 14, 2011, 06:27:48 PM »
Greg, I also heard that not all units shipped the plug.  Confirm they are still shipping the plug.  Why is the yellow sheet not included?
Offline gofission
« Reply #9 on: April 15, 2011, 01:31:23 PM »
OK took some pics. These are after I moved it up 1/4 inch. I think it will be ok. Launching the boat in an hour.ila_renderedila_rendered
« Last Edit: April 15, 2011, 01:36:17 PM by gofission »
« Reply #10 on: April 15, 2011, 02:04:03 PM »
How much of that paint did you get on the transducer.  Did it cover the bottom of the ducer also?????
Offline Roddy
« Reply #11 on: April 15, 2011, 03:34:08 PM »
Get the paint off the XDUCER ASAP!!!!!! :-X :'( Roddy
Offline gofission
« Reply #12 on: April 15, 2011, 05:12:56 PM »
the paint is water based. The bottom of the TD is painted with transducer paint.
The unit works ok but test conditions could not be worse. The TD throws  a wall of water onto the engine cowl.
« Reply #13 on: April 16, 2011, 11:43:23 AM »
YEP....anything above 1 or 2 mph will probably do just that.
A lot of posting on this forum about transducer location, speed, roostertail and loss of depth at speed.
Offline gofission
« Reply #14 on: April 16, 2011, 04:26:30 PM »
Found the plug in the box under a small section of folded cardboard seperate from the transducer parts. Dont know why they didnt just put in with the other parts.
« Reply #15 on: April 16, 2011, 04:52:14 PM »
Makes ya wonder if others have thrown it away not knowing it was there.  Did you have a yellow sheet on the plug?  Greg, did say they stopped shipping that awhile back.  It would have been a good reminder...
« Last Edit: April 16, 2011, 06:41:58 PM by sonar2000 »
Offline gofission
« Reply #16 on: April 16, 2011, 05:05:18 PM »
Yes it was in a bag with the plug. Since nothing in the installation guide mentioned the plug, there was no reason to root through the packing materials. I would imagine a lot get tossed. Hope it helps.
« Last Edit: April 16, 2011, 05:07:16 PM by gofission »
Last post March 10, 2010, 12:54:59 PM
Last post September 01, 2010, 12:37:02 PM
by stoporilshoot
Last post September 02, 2010, 02:45:53 AM
by stoporilshoot
Last post December 17, 2010, 10:50:16 AM
Last post August 19, 2011, 01:42:45 AM
Last post December 06, 2011, 08:44:16 AM
by jonnialvarado
Last post January 08, 2012, 05:37:08 PM
Last post January 09, 2014, 06:41:57 PM
by JimV
