Author Topic: Best way to test if Fish ID is working?  (Read 12745 times)
Offline Fly 1
  • Unit(s): 798 ci HD Side Imaging
  • Software: navionics
  • Accessories: none
« on: October 26, 2014, 07:55:07 AM »
Hi Guys,
Yes I know, find some fish first!  ;)
Due to bad weather, only had some limited tested testing over 3 days
My old 385 ci used to indicate fish symbols with fish,
Cannot get my new 798 ci HD SI to show the fish symbols, even if I turn the sensitivity up?
I had a lure at about 8ft in 20ft of water which I could clearly see but when I switched over to fish ID I though it would show as a fish?
lastly, as I have seen on the forum, a guy used a weighted water bottle filled with air, would this be a good test?
..........Gary
Offline Free2Fish
  • Unit(s): 386 ci, 999 HD SI
Re: Best way to test if Fish ID is working?
« Reply #1 on: October 26, 2014, 11:25:57 AM »
If a lure showed up as a fish, the unit wouldn't be working very well.
The water bottle should work since, as i understand it, sonar detects fish by bouncing the sound wave off the air in their fish bladder.
I tested my unit by turning on fish ID when I ran into a big school of baitfish. I couldn't see any arcs but when fish ID was turned on about a dozen fish showed up.
Offline Fly 1
  • Accessories: none
« Reply #2 on: October 26, 2014, 06:58:43 PM »
Tks, might try the water bottle!
« Reply #3 on: October 27, 2014, 08:03:55 AM »
I've read of successful Fish ID tests using tennis balls ...because of the trapped air inside ...
Offline Fly 1
  • Accessories: none
« Reply #4 on: October 27, 2014, 08:27:17 AM »
Tks Rickie
Thats a novel idea,
Might go for 3 items,
water bottle/tennis ball/ping pong ball
........Gary
« Reply #5 on: October 28, 2014, 09:03:58 AM »
Gary, I don’t know what the units look for in the sonar returns before they will display a Fish ID+ Symbol but I know there has been some testing done with ping pong balls before as I remember seeing some posts about it a very long time ago.  Please post back your results.  Don’t forget the Fish ID+ Sensitivity menu that can be adjusted as well  Adjusting the normal Sensitivity menu will not affect if and when the unit uses a Fish ID+ Symbol or not but the Fish ID+ Sensitivity will.
Offline Fly 1
  • Accessories: none
« Reply #6 on: October 28, 2014, 06:59:30 PM »
Hi Greg,
I spoke to the Australian Humminbird agent yesterday, they indicated that the ball and bottle test would be a good idea and if I then do not get a "fish" signal,
return the unit to Humminbird,
the other part of the conversation was about the rooster tail, I had fixed temporary with electrical tape and they are kindly sending me the part to stop that,
Lastly, I did ask about whether I needed to switch to 455 Khz using side scan, the agent indicated that I shouldn't have to with the compact transducer missed with the unit, (798 ci HD SI)
Weather did not allow me to get more than 3 short days on the water and is still pretty ordinary, hope to get on the water again in a couple of weeks, or sooner hopefully
...........Gary
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« Reply #7 on: March 13, 2015, 03:53:22 PM »
I know the international unit (same I have) do not display all the time the fish ID. If you search on this forum y ou may see my oldest post regarding this.
I have done many test (trust me) and compare them to my older unit 565 and saw that even on ice fishing i was not able to see fish on my 798 like I was on my 565 for same spot.
even when doing switch fire when jigging....
hope the new software will fix all that
Offline Fly 1
  • Accessories: none
« Reply #8 on: March 13, 2015, 05:58:44 PM »
Tks for the reply,
appears to be working again?
......Gary
Last post August 20, 2011, 01:41:11 AM
by kosmo
Last post January 22, 2012, 05:04:12 PM
by bayouxpress
Last post April 30, 2012, 04:43:36 PM
Last post July 11, 2012, 12:56:40 PM
Last post June 26, 2013, 05:33:23 PM
by browni1983
Last post March 21, 2014, 04:08:35 AM
by peterv6i
Last post April 16, 2015, 12:51:34 AM
