Author Topic: Fish Id not working on HB 597c  (Read 9386 times)
Offline Murfreesboro1
  • Unit(s): 597c
  • Software: ?
  • Accessories: Transducer
« on: June 25, 2012, 10:54:05 PM »
I know this forum is for the bigger HBs  but has anyone had a problem with this unit as concerns the Fish ID not working?  I was in the boat and did everything that the manual said to do.  The simplest thing to do is to reset the unit defaults and then turn on the Fish ID and it should be on also increased the Fish ID Sensitivity.  Not doing it.  Thanks if has had this same problem and for your wisdom.  I just bought this unit.
Re: Fish Id not working on HB 597c
« Reply #1 on: June 26, 2012, 09:45:55 AM »
Sounds to me like you have set everything correctly.
What Beam Select menu setting are you using?
What SwitchFire menu setting are you using?
What water depth is this in?
Can you make a screen snapshot of the unit showing fish but no Fish ID symbols?
« Last Edit: June 26, 2012, 09:49:55 AM by Humminbird_Greg »
« Reply #2 on: June 26, 2012, 03:39:51 PM »
Rickie posted this on another thread.
Hit "Menu" twice to get into the Main Menu System...
Cursor over to the "Sonar" tab...
Cursor down to "FishID"...
Cursor right to bring up "Off - On"...
Cursor down to highlight "Off  - On"...
Cursor to "On"....
Offline Johnf
  • Unit(s): 597 ci HD DI, 110 Fishin Buddy
  • Software: 6.09
  • Accessories: Navionics premium south
« Reply #3 on: July 10, 2012, 10:30:52 AM »
The fish ID on my 597 ci HD DI unit was turned OFF when I received it new in unopened box last week.  As stated, it can be turned on in Sonar menu.
« Reply #4 on: July 11, 2012, 12:56:40 PM »
Is it working now?   ???
Reading the original post again; he states that he turned Fish ID on as well as turned up the Fish ID Sensitivity.  Is it showing the Fish ID Symbols now?
Last post April 21, 2010, 02:59:52 PM
by netman
Last post June 25, 2011, 10:11:07 AM
by Daz
Last post November 18, 2011, 12:32:34 PM
Last post October 19, 2011, 10:12:11 AM
Last post February 10, 2012, 08:12:53 AM
Last post February 27, 2012, 07:38:04 PM
by rdstair
Last post March 23, 2012, 03:23:06 PM
by rheykoop
Last post March 13, 2015, 05:58:44 PM
by Fly 1
