Author Topic: Xnt-9-180-si-t transducer test  (Read 8481 times)
Offline browni1983
  • Love my birds.... Clearly better
  • Unit(s): 798 CI SI HD, 898 C SI Combo
  • Software: 6.2
  • Accessories: Interlink, barometer, GPS
« on: June 25, 2013, 11:08:32 PM »
Recently had my transducer to break the bracket and slam against my aluminum boat. I replaced the bracket and it didnt nick the cable or anything but I feel that the system has been finicky since then. I'm a very good electronics ( degreed) and computer guy. Can I check the xducer with an ohm meter and check tolerances to tell if the xducer was damaged? I can hear the pings while its parked in the garage and it definitely pings slower than my 898 at 455 / 83 and 200. I tried disconnecting the units from the interlink hoping that would solve erratic behavior but it didn't.
Re: Xnt-9-180-si-t transducer test
« Reply #1 on: June 26, 2013, 02:25:57 PM »
No, a simple ohm check would not be able to detect a degradation of the sonar.  You would need to use more specialized equipment to be able to do that.
Offline browni1983
  • Software: 6.2
« Reply #2 on: June 26, 2013, 02:28:14 PM »
is there a way or key identifiers that would indicate a faulty xducer?
« Reply #3 on: June 26, 2013, 03:02:38 PM »
The best test would be to swap your 798 and 898 units around and look at the 2D and Si sonar on each for a comparison.
Typically when 2D sonar starts to go bad it will show really shallow water depth readings or even a very thick surface clutter line.  That is when they are still working.  The Si sonar typically starts getting less sensitive until it fails altogether.
Offline browni1983
  • Software: 6.2
« Reply #4 on: June 26, 2013, 05:33:23 PM »
Thanks Greg
Last post October 26, 2019, 07:53:17 AM
by Rüdiger
Last post March 21, 2014, 04:08:35 AM
by peterv6i
Last post March 13, 2015, 05:58:44 PM
by Fly 1
Last post April 16, 2015, 12:51:34 AM
Last post June 09, 2015, 07:14:07 PM
by Long Hair
Last post December 17, 2015, 02:57:12 PM
Last post August 03, 2022, 08:47:15 PM
Last post May 22, 2023, 06:25:46 PM
by danlaboucane
