Author Topic: Low Voltage on 997csi  (Read 7833 times)
Offline Fishinfinatic
  • Unit(s): 997 and 788
  • Software: 5.840
  • Accessories: interlink ans weathersense
« on: October 09, 2014, 02:07:38 PM »
Help!
I have a 997csi and the voltage reads 9.9-10.2 volts.  I get 12.4 volts at the connector going into the back of the unit.  I have problems with the unit reading bottom.   Example - Reads 38 ft when only 6 ft.  No recent changes and worked well in the past.
Thanks for any help you can provide.
Re: Low Voltage on 997csi
« Reply #1 on: October 09, 2014, 02:21:15 PM »
I would start looking at the wiring between the power cable for the unit and the battery it is powered from.  Any loose or corroded connection can rob the unit of the power it needs to work properly – which can include how its sonar works.  While you may read 12.4 volts on a non-loaded (the unit is not connected and powered on) connection the unit may not be able to get the current it needs.  Be sure to check the fuse, fuse holder and battery terminal connections.  I recommend the unit be on its own set of wires (16 AWG multi-stranded copper) and fuse for best results.  Solder and seal all electrical connections.
Last post September 22, 2022, 10:42:47 AM
by ezfishn
Last post October 28, 2009, 07:44:35 PM
Last post March 04, 2011, 07:42:49 PM
Last post September 07, 2011, 09:09:30 PM
Last post September 16, 2014, 08:01:04 AM
Last post September 08, 2015, 05:07:42 PM
by Mark Saikaley
Last post July 05, 2017, 05:22:51 PM
Last post August 28, 2017, 10:01:22 PM
