Author Topic: 997csi is becoming slowwwwwwww  (Read 29319 times)
Offline Smellybox
  • Unit(s): 997
« on: September 14, 2014, 08:33:24 AM »
My 997 c si is becoming very slow, it takes about 10 seconds to load maps, about 5 seconds to delete waypoints, it seems to act like an old out dated computer.
 If I run a lakemaster map on it takes forever to load so I just stick to Navionics maps.
The last update I did to it slowed it right up so I went back to the previous update.
I have a couple thousand waypoints on it could this be the issue?
 Time to upgrade to an onix but I want to wait until they get any bugs out of the first run of onix fish finders.
Re: 997csi is becoming slowwwwwwww
« Reply #1 on: September 14, 2014, 11:04:43 AM »
Clear the Current Track under the Nav tab at least once per day ...
Also...to test if the current number of waypoints is slowing the unit down ...
*Export the Nav data to a formatted SD Card  ...
*Download the Nav data to HBPC for verification that the waypoints are safely in a backup location...
*Delete all Nav data from the unit...(newer software versions call this Format Nav Directories)...
*Test the unit now with no Nav data in the unit memory...
« Reply #2 on: September 15, 2014, 12:46:32 PM »
That many waypoints can slow down the 997 units.
Offline Smellybox
  • Unit(s): 997
« Reply #3 on: September 16, 2014, 07:49:25 AM »
ok ill save them to sd and delete them off the unit and see what happens
« Reply #4 on: September 16, 2014, 08:01:04 AM »
Be sure and open those waypoints in HBPC before you delete them from the unit...
There's nothing worse than finding out there's a problem with the SD Card and your "un-backed up" waypoints cannot be retrieved...
That makes for a bad day ...
Last post September 22, 2022, 10:42:47 AM
by ezfishn
Last post October 28, 2009, 07:44:35 PM
Last post March 04, 2011, 07:42:49 PM
Last post September 07, 2011, 09:09:30 PM
Last post March 12, 2013, 11:48:11 AM
Last post October 09, 2014, 02:21:15 PM
Last post September 08, 2015, 05:07:42 PM
by Mark Saikaley
Last post July 05, 2017, 05:22:51 PM
