Author Topic: onix non si using a si ducer  (Read 13243 times)
Offline skigill
  • Unit(s): 1197c NVB, 798c
« on: August 27, 2014, 11:53:05 PM »
If you have non si onix and put an onix si transducer will be able to see si?
  • Moderator
Re: onix non si using a si ducer
« Reply #1 on: August 28, 2014, 10:20:50 AM »
No.
You can use a non-SI ONIX unit with an Si transducer but to do so you would need to either connect to the SI transducer through an Ethernet connection to an SI ONIX unit or use one of the Sonar Modules (SM2000, SM3000).
[EDIT: incorrectly listed SM1000 module.]
« Last Edit: September 10, 2014, 02:19:09 PM by Humminbird_Greg »
Offline skigill
« Reply #2 on: August 28, 2014, 10:56:59 PM »
Thanks Greg. I saw an onix ci for a great price, but I have to have si. I guess you could use a 360 for si?
  • Moderator
« Reply #3 on: September 09, 2014, 09:29:50 AM »
Yes you can.  the 360 is Si sonar that rotates or can be "parked" and used as an Si (only) transducer.
Offline skigill
« Reply #4 on: September 10, 2014, 01:51:55 PM »
Greg, if I get the sm2000, what else will I need? I assume an si transducer. I also have a 360 and Ipilot link. Will I need an ethernet hub?
Or would I be better off selling the 10ci and buying the 10ci si? thanks Paul
Offline skigill
« Reply #5 on: September 10, 2014, 01:54:05 PM »
Greg, would the sm1000 work? The ports list a 2d transducer, but not the si. Thanks Paul
  • Moderator
« Reply #6 on: September 10, 2014, 02:18:00 PM »
No, the SM1000 is for 2D sonar only.  For the Si sonar you would need to go up to the SM2000 (or SM3000).
Let me fix my prior post...
Offline skigill
« Reply #7 on: September 10, 2014, 04:37:51 PM »
Thanks Greg. Is there any advantage in using the 10ci si vs the 10ci with sm2000 and si ducer?
« Reply #8 on: September 10, 2014, 09:53:27 PM »
You could always sell me the CI .....really cheap and I will try it out. >:D
  • Moderator
« Reply #9 on: September 11, 2014, 09:58:14 AM »
Well there is what Bob B said.  ;D
Except for overall cost; I don't know that there is any advantage with either as a stand alone device.  With other devices there may be but I don't know of anything right now.
Last post April 20, 2010, 06:43:25 AM
by YankeeDoodler
Last post December 09, 2011, 01:26:06 PM
Last post February 01, 2012, 05:07:06 PM
Last post February 22, 2013, 02:52:11 AM
by Rickard
by Nitro78
Last post January 31, 2016, 06:42:39 PM
by JoeyWelch
Last post February 29, 2016, 09:54:06 PM
