Author Topic: 987si ducer  (Read 7310 times)
Offline mulliemark
987si ducer
« on: February 21, 2013, 04:16:06 PM »
I have a couple of questions , can i use the hdsi 180t ducer with this unit and  if I can would i see a sharper image? I know the 800 cycle wont work
also are these units really that hard to see in sunlight ? would a person need one of those visors to shade it? and any general opinions as to how the picture stacks up against the 997
thnx
mark
Offline Rickard
Re: 987si ducer
« Reply #1 on: February 21, 2013, 04:38:09 PM »
Hi Mark,
I suppose you have a 987? I have a 981 that has the same sonar capacity and have used the SI 160 and the HDSI 180 transducers alot. The image gets a little bit better at 455 kHz with the HDSI 180, but you will miss the 262 kHz SI frequency. I think the SI 160 is a better choice for the 987/981 models. If you want to have dramatically better results you should build your own transducer system with a LSS-2 transducer... but this is close to treason..  ;) You can read about how this is done in the thread Interfacing a HB with the L... LSS-2 in the section on Towfish construction.
Rickard
Offline mulliemark
Re: 987si ducer
« Reply #2 on: February 21, 2013, 04:43:40 PM »
rk where would the 262 freg be useful? and is it hard to see in the daylight, I have a 798 with a hd ducer  which takes perty sharp pics and a 797c with the stock ducer  that has an acceptable pic I would hate to lose more detail than i currently have with the 797 , what good is bigger if you cant tell what something is
mark
Offline Rickard
Re: 987si ducer
« Reply #3 on: February 22, 2013, 02:52:11 AM »
The 262 kHz is useful in long distance scanning. It has much better range than 455 kHz. Resolution is worse, but it can be good enought when one only needs an overview. Most units are unable to display the full resolution in the transducer system. One must review recordings with a computer to see all details and then the difference between different transducers becomes very evident.
I don't know if the display in the 798 needs shading in sunlight. I don't use any such means with my 981, though.
Rickard
Last post March 24, 2010, 06:00:07 AM
by Fishtale
Last post March 31, 2011, 01:51:07 PM
Last post February 01, 2012, 05:07:06 PM
Last post June 27, 2014, 12:20:45 PM
by hays47
Last post September 11, 2014, 09:58:14 AM
Last post October 05, 2014, 10:47:54 AM
by studemaker
Last post October 17, 2014, 07:46:36 PM
by hays47
Last post November 07, 2015, 09:17:06 AM
by N9Phil
