Author Topic: Second ducer for the 798SI  (Read 12893 times)
Offline Dragline
  • Unit(s): 798si
« on: January 22, 2012, 01:58:12 AM »
This may be a simple request but I have had no luck researching it on the web. I have the 798SI with the transom ducer but I want to have a second in hull ducer for sonar reading while at speed when the transom ducer will not work.
I have heard of this being done, if so how is it done and what are the components required and the wiring configuration??
Any help at all would be greatly appreciated
Offline king0581
  • Unit(s): 798ci si
Re: Second ducer for the 798SI
« Reply #1 on: January 23, 2012, 07:48:34 PM »
« Reply #2 on: February 01, 2012, 05:07:06 PM »
If you have a fiberglass boat:
XP-9-20 inside-the-hull DualBeam transducer
AS-Si-DB-Y transducer splitter cable
Plug the standard CSi transducer into the plug on the AS-Si-DB-Y cable labeled “Side Imaging”.  Plug the XP-9-20 into the plug labeled “DualBeam” and the third connector goes into the unit mounting base in place of the transducer.  Launch boat, power unit on and go!
Last post April 20, 2010, 06:43:25 AM
by YankeeDoodler
Last post December 09, 2011, 01:26:06 PM
Last post December 29, 2011, 01:53:01 PM
Last post January 15, 2013, 08:26:19 AM
Last post June 27, 2014, 12:20:45 PM
by hays47
Last post September 11, 2014, 09:58:14 AM
Last post October 05, 2014, 10:47:54 AM
by studemaker
Last post October 11, 2023, 04:55:01 PM
by nicknight
