Author Topic: Depth Reading will be intermittent  (Read 5944 times)
Offline Spidey
« on: August 03, 2014, 01:00:51 PM »
The Depth on my 898HD SI will not show true depth.  It will read 1.5 then start flashing. I am really in depths of 10-15 ft. I have changed the update from 6.6 to 6.7 and still no change.  I haven't went back to 6.4 or earlier. Is there anything else, I could try?
Re: Depth Reading will be intermittent
« Reply #1 on: August 12, 2014, 10:59:50 AM »
Welcome to the Humminbird Side Imaging Forums Spidey.
You can start with trying to give us a little more information here:
Is this the only sonar unit on the boat?
If not, does this happen with only your 898 unit on and nothing else on the boat running (including motors, aerators, etc…)?
Does this happen at all water depths?
Are you only using the stock XHS-9-HDSi-180-T transducer that came with your 898 unit?
Have you tried adjusting the Surface Clutter menu (both to its minimum and maximum settings)?
Do you know of anyone else with a Humminbird unit or do you have a second Humminbird unit, such that you could connect the transducer and power to you 898 unit and see if the same thing happens on the other transducer or not?  This would not have to be another Side Imaging model unit as most will work for this depth reading test – just make sure it is not a DI model unit’s transducer.  Test their unit on your 898’s power and transducer connections too.
Last post June 23, 2010, 09:24:55 PM
by reelman
Last post June 11, 2010, 08:42:41 PM
by majflyboy
Last post October 31, 2012, 03:42:56 PM
Last post May 13, 2013, 09:29:14 AM
Last post May 29, 2014, 08:41:20 AM
Last post August 12, 2014, 12:42:12 PM
Last post July 28, 2014, 12:32:18 PM
Last post October 25, 2015, 11:07:48 AM
by fishbone
