Author Topic: 1197c_6.490 Firmware.  (Read 8900 times)
Offline Renoboss
  • Unit(s): 2x Helix 9 G3N / CF-19mk3
  • Software: V2.28, Autochart Pro
  • Accessories: Ethernet Switch
« on: July 12, 2014, 05:59:00 PM »
Hi there,
Can anyone upload the firmware:  1197c_6.490.bin ?
to be placed in the download section.
Or is V6.310 the latest before V6.640 ?
Thanks !!
(Used HB997cxi ,  HB1197cxi , DrDepth BT+SS.)
Re: 1197c_6.490 Firmware.
« Reply #1 on: July 12, 2014, 09:10:30 PM »
Yes, 6.310 was the last.....never was a 6.49 for the 1197
Offline Renoboss
« Reply #2 on: July 13, 2014, 02:43:11 AM »
Oke,
That explains why it wasn't in the download section.
I thought i saw i mentioned in another post by Greg.(of HB offcourse)
iŽll try to search that post again.
will first use V6.310.
Thanks !!
« Reply #3 on: July 13, 2014, 03:27:08 PM »
If you don't have the heading sensor GPS or anything else that requires a higher rev.  6.310 is the way to go.
Offline Renoboss
« Reply #4 on: July 13, 2014, 03:46:14 PM »
Thanks Bob,
Still i've a problem i'm not able to fix !!
I bought a used 1197cxi to finally use de SS Mosaic. (my 997cxi doesn't has Ethernet)
Currently firmware 5.84  (from 6.60 -> 6.30 ->6.18).
IP Adress: 169.254.41.26   ,  Mac Adress:  00:1a:29:00:00:00
I've checked the network cable twice and the connections are perfectly o.k.
On my newly setup Thoughbook MK3 I'm running Win7 ultimate 32 bit.
DrDepth V5.1.8  , firewall enabled on all possible type of networks.
Cable IP-connector is at IP:  192.168.0.217 Dr.Depth is running ok on NMEA !!
In NMEA/COM setting  Humminbird checked  and No NMEA checked.
But with network cable I can't get a connection !
It's just displaying the message "connected to Ethernet, waiting for position data"
I checked all the forum-post but no solution found yet.
Perhaps any-one having the same problem?
Last post March 12, 2012, 09:52:04 AM
Last post April 21, 2012, 07:15:03 AM
Last post August 06, 2012, 03:42:11 PM
Last post April 02, 2013, 09:39:11 PM
Last post May 16, 2013, 05:15:18 PM
by pfleming
Last post June 06, 2013, 07:57:59 PM
by Gattlin
Last post November 18, 2013, 09:58:37 AM
Last post April 18, 2014, 07:25:38 PM
by Yrral3215
