Author Topic: Firmware updates  (Read 14919 times)
Offline Jdeee
  • Unit(s): 1198
  • Software: 6.10
  • Accessories: External gps HS
Firmware updates
« on: April 17, 2012, 09:27:33 PM »
When you update the firmware do you need to start with the next update or can you just update by using the latest?
eg 798cihd 5.410 to 5.500 to 5.590 ...............
Or 5.410 directly to 6.250
Also is there any problem to updating 798ciX hd with these updates
Offline Shooter00
  • Unit(s): 798c SI 788ci HD
Re: Firmware updates
« Reply #1 on: April 17, 2012, 10:01:01 PM »
Just update to the latest and you'll be fine.
Here is a list of the latest updates available for the different units.
http://www.humminbird.com/FAQ.aspx?ContentId=2904
« Reply #2 on: April 18, 2012, 10:03:23 PM »
If you are not registered on  HB you can get the downloads here on the forum under downloads.
And select your unit..
Offline George
  • Software: Always up todate
« Reply #3 on: April 21, 2012, 07:15:03 AM »
Jdeee
The one think that is nice about the updates is that you can install any of the updates for your unit at anytime.  On this site most of the older updates along with the latest is posted for each of the units.  So if you do not like the latest update for any reason you can reinstall an older version.
George
Last post April 11, 2009, 11:09:32 PM
Last post April 13, 2009, 05:29:04 PM
Last post December 03, 2013, 10:36:26 PM
Last post April 18, 2014, 07:25:38 PM
by Yrral3215
Last post July 13, 2014, 03:46:14 PM
by Renoboss
Last post August 04, 2014, 10:40:20 AM
Last post August 15, 2014, 08:49:34 AM
by Beaulieu80
Last post June 11, 2016, 09:32:58 PM
