Author Topic: Should I update firmware?  (Read 12425 times)
Offline spes
« on: April 02, 2013, 06:58:54 PM »
Hello,
New out of the box 798 hd si.
Should I update the firmware?
I have  seen posts argueing both ways on this.
Re: Should I update firmware?
« Reply #1 on: April 02, 2013, 07:11:22 PM »
What version did the unit come with?
Do you need any of the new features that the new update offers?  Are you having any issues with the current version?
Offline spes
« Reply #2 on: April 02, 2013, 07:32:03 PM »
I havn't even installed it yet.
I did just check, the firmware is 6.250
The only feature I have read about that sounded interesting was something  "casting distance" from waypoints.
I thought I might mark boulders around where I fish and create a safety zone away from them ;-)
« Reply #3 on: April 02, 2013, 08:40:51 PM »
I am trying to play devils advocate  >:D here!  You bring up a good reason to do the upgrade.  Personally, I would try the existing software out on the water first.  Then do the update and see if it makes that much of a difference.  You can always go back.
Before you try to go out and fish, I do recommend that you spend time out on the water just scanning, making recordings, and working with the settings, etc.  By making recordings you can come home and play them back on the unit, adjust settings, make some snapshots, etc.
Offline spes
« Reply #4 on: April 02, 2013, 09:09:16 PM »
That brings up a good point I would like to ask..
If I record on the water with totally bogus settings...
When I get it home  and play it back,, can I clean up the recording and see what settings are wrong?
« Reply #5 on: April 02, 2013, 09:39:11 PM »
Yes, you can manipulate some settings, even create waypoints and snapshots during playback.
Last post November 11, 2009, 01:13:25 PM
Last post March 22, 2010, 10:23:29 PM
Last post April 19, 2010, 01:58:32 PM
Last post June 13, 2011, 12:20:16 PM
Last post March 12, 2012, 09:52:04 AM
Last post April 02, 2020, 09:40:21 AM
Last post July 13, 2014, 03:46:14 PM
by Renoboss
Last post May 04, 2015, 10:20:31 AM
by Beaulieu80
