Author Topic: Help With HumminbirdPC and Windows 7 Professional  (Read 21537 times)
Offline Bayou Basser
  • Unit(s): Helix 5 Chirp DI GPS G3, Helix 7 Chirp M
  • Accessories: None
« on: May 27, 2014, 11:29:33 AM »
Bought a new computer with Windows 7 Professional.  After setting it up and installing Office XP Professional I installed HumminbirdPC and everything worked fine.  About a week later I installed COMODO firewall and after the installation and reboot Windows did an update.  Ever since then I get "HumminbirdPC.exe has stopped working" message when I try to run it.  I've uninstalled HBPC and did a re-install several times with the same results.  I NEED HELP!!
Re: Help With HumminbirdPC and Windows 7 Professional
« Reply #1 on: May 27, 2014, 01:16:27 PM »
I would look through the 'COMODO' documentation and see if there
is anything about trusted applications.
There may be a 'COMODO' system file, where you can enter in application names that it does not recognize.
Although, I don't think that HumminbirdPC is a installed running application.
I think the operating system just loads it when needed, then clears it upon user exit.
Not sure.
  • Accessories: None
« Reply #2 on: May 27, 2014, 10:42:01 PM »
Thanks ITGEEK.  One of my sons did some checking and found that its BITDEFENDER anti-virus that's causing the problem.  When its disabled HBPC will run, when its active it will not.  Has anyone run up against this problem?
« Reply #3 on: May 28, 2014, 10:27:38 AM »
Bayou:
Here's a shot in the dark: Uninstall HumminbirdPC, and re-install with
BITDEFENDER running.
  • Accessories: None
« Reply #4 on: May 28, 2014, 10:32:33 AM »
Thanks for the reply.  We have tried that with no success.  We are going to contact Bitdefender to see if they can give us a fix.
Thanks again.
Last post February 11, 2010, 02:28:55 PM
by Rocketman783
Last post February 24, 2011, 08:48:38 AM
by Moose1am
Last post July 02, 2012, 10:12:32 AM
by Roddy
Last post October 23, 2012, 06:22:35 AM
by Rickard
Last post March 27, 2013, 11:16:00 PM
Last post May 08, 2013, 10:18:51 AM
by matt@reefmaster
Last post August 19, 2013, 04:39:05 PM
by bflipn
Last post March 19, 2014, 12:39:44 AM
by Derek
