Author Topic: Windows XP or Windows 7  (Read 24901 times)
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« on: February 23, 2011, 02:08:29 PM »
If you could choose between XP and 7 to use for HB PC, the different viewers, and Google Earth,
which would you choose?
Re: Windows XP or Windows 7
« Reply #1 on: February 23, 2011, 05:28:12 PM »
I have seen a post noting a problem with Win7 Pro 64 bit version.....have to trick it into running in 32 bit mode.    I have Win7 Pro 32bit and no problems so far.
Offline benamen
  • Unit(s): 997C SI
  • Software: 4.75
  • Accessories: none
« Reply #2 on: February 23, 2011, 08:17:13 PM »
Windows 7 allows you  to run programs in Windows XP compatibility mode if required. Just right click on the shortcut and go to the compatibility tab.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #3 on: February 23, 2011, 11:46:58 PM »
Thanks for the replies.
Going to buy another iMac with Snow Leopard or Lion OS.
Need to add XP or 7 to use programs for HB.
Have access to both.
Benamen.... that's what I was looking for.
Bob B.... I think the copy of 7 is 64 bit.
many times you don't know, what you don't know
I love this place....LOL
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
« Reply #4 on: February 24, 2011, 08:48:38 AM »
Windows 7 comes in a 32 bit version and a 64 bit version. Note: the 64 bit version runs programs in either 64 bit or 32 bit.
I went with Windows 7 Home 64 bit pre installed on my new computer.  I have not tried to run the Humminbird Software yet with this computer.
One thing to remember when using Windows 7 64 bit version is that there are two different program directories.  One is for 64 bit only programs and the other is for 32 bit programs.  Go to your C:\ drive and check out the difference between these two.
Program Files (x86) is for 32 bit program files.  Program Files is for the 64 bit programs.  When you install a new program on your Windows 7 64 bit OS you must make sure that the program files are installed in the proper directory.
Regards,
Moose1am
Last post January 17, 2010, 08:27:58 AM
by pmburesh
Last post February 06, 2010, 03:14:00 PM
by SIView
Last post February 11, 2010, 02:28:55 PM
by Rocketman783
Last post August 03, 2010, 12:12:31 PM
by Rocketman783
Last post July 02, 2012, 10:12:32 AM
by Roddy
Last post May 28, 2014, 10:32:33 AM
by Bayou Basser
Last post April 02, 2015, 12:56:38 AM
Last post August 11, 2015, 06:21:58 PM
by lancepeterson
