Author Topic: Windows 7 and son2xtf 1.001?  (Read 25486 times)
Offline Rickard
« on: July 01, 2012, 03:22:44 AM »
Hi,
I need to install son2xtf on my new computer with Windows 7. But none of the two versions of son2xtf (one is for XP, the other for Vista) is explicitly designed for Windows 7. Which one should I use with Windows 7?
Regards,
Rickard
Offline Rüdiger
Re: Windows 7 and son2xtf 1.001?
« Reply #1 on: July 01, 2012, 03:30:59 AM »
Hi,
Regards,
Rickard
Hi Rickard
Without knowing it, I think you should try using the XP version. Vista needed for all the designated driver, Win7 should be kompatiebel but with XP.
mvh
Rüdiger
Finding is better than losing
Offline Roddy
  • Scan,scan and rescan
« Reply #2 on: July 01, 2012, 11:24:22 AM »
Rickard, Had the same with my new HP dv7-6178 with Windows7.
The only fix I know that works it install Window7 Office Pro and then install the Virtual Add On witch will run XP programs.
I had to do this on each of my new lap tops! $$$$$$$.
It is a pain in the butt to use also.
Good luck Roddy
Scan,Scan and Rescan Roddy
Offline Rickard
« Reply #3 on: July 02, 2012, 04:34:44 AM »
Thanks Rüdiger and Roddy,
I have W7 Enterprise and tested with installing the XP version. I got a message the Microsoft.NET Framework 1.1.4322 was needed. I installed it and then son2xtf. Son2xtf works well.
However, SiView doesn't perform well. Some recordings, also old recordings, become 'diagonalized'. I have never seen this before. It's strange that some recordings look normal, some not.
Fortunately, Humviewer installed without problems and show the recordings which were diagonalized in SiView without any distortions.
Rickard
ADDED: I just discovered the 1.0.0.6 patch for SiView 1.0.0.5. No more diagonalized images, problem solved!!
« Last Edit: July 02, 2012, 09:42:49 AM by Rickard »
Offline Roddy
« Reply #4 on: July 02, 2012, 10:12:32 AM »
Rickard, Good deal and now for some on the water time!
Roddy
Last post May 17, 2010, 03:24:37 AM
by ruiner
Last post August 01, 2010, 06:29:24 PM
by equinox
Last post January 10, 2012, 12:56:26 AM
by T.G
Last post March 22, 2013, 09:04:51 PM
by wickgofish
Last post November 12, 2018, 02:29:38 PM
by wami
Last post May 27, 2019, 12:17:11 PM
by LHayden
Last post April 29, 2021, 08:40:08 AM
by BobRisner
Last post November 21, 2021, 10:40:49 AM
by abraquelebout
