Author Topic: ethernet connection  (Read 9133 times)
Offline Charlie1
  • Unit(s): 898c si & 998c si
  • Accessories: interlink
ethernet connection
« on: May 25, 2014, 04:25:07 PM »
How do I make a Ethernet connection between 899 & 859
Offline Trout Bum
  • Unit(s): 958 HD, 788 ci HD
  • Software: 6.640
  • Accessories: aux speed & temp, ethernet
Re: ethernet connection
« Reply #1 on: May 26, 2014, 08:41:38 AM »
You will need an Ethernet cable of the correct length and (2) adapter cables. The adapter cables make the transition from the Ethernet cable connectors to the connector required for your units.
Just plug it all together, make the settings you want in your units (shared transducers or whatever) and your good to go.
2013 Lund Rebel 1650 XL Sport
60 hp Mercury 4-stroke
Humminbird 998c HD SI, 958c HD & 788ci HD
Minn Kota Terrova w/i-pilot
« Reply #2 on: May 27, 2014, 02:37:17 PM »
Welcome to the Humminbird Side Imaging Forums Charlie1.
Trout Bum is correct.  You will need two (2) of the AS-EC-QDE Ethernet Adapter cables plus an AS-EC-XXE cable of the correct length.  That AS-EC-XXE cable comes in 2, 10, 15, 20 and 30-foot lengths and the length of the cable replaces the “XX” in the part name.  So a 10-foot cable would be AS-EC-10E.
As far as sharing transducers goes; you will need to make sure that both units are running the correct software version (6.940 or higher).  You can check your “My Humminbird” account to see if it is available yet.
What model 859 do you have:
859ci HD
859ci HD DI
859ci HD XD
Last post October 10, 2010, 10:29:18 PM
by crappie1
Last post March 05, 2014, 11:11:11 PM
by MT-ED
Last post March 10, 2014, 12:23:42 PM
Last post March 06, 2014, 01:11:53 PM
by lawnman53
Last post March 27, 2014, 07:26:19 PM
Last post February 16, 2015, 07:15:36 AM
by palajam
Last post February 17, 2015, 02:37:14 PM
Last post November 20, 2024, 05:52:48 PM
by OceanAI
