Author Topic: no gps connection  (Read 9419 times)
Offline crappie1
  • Unit(s): 798cisi
no gps connection
« on: October 07, 2010, 09:49:12 AM »
I have a 798cisi unit and the gps keeps going out.  I have talked to humminbird and sent the unit back to them twice to be fixed.  Somedays it works fine and others it won't turn on.  It works for short periods of time and then it says no gps connection and won't pull up the gps mapping screen even though everything else works fine.  Can anybody help???
Offline RzorbackAngler
  • Unit(s): 788 CI, 898c SI
  • Software: 5.4, 5.5
  • Accessories: Interlink
Re: no gps connection
« Reply #1 on: October 07, 2010, 01:11:43 PM »
I have found that bending the plug-in connectors slightly seems to help.
Offline crappie1
  • Unit(s): 798cisi
« Reply #2 on: October 07, 2010, 05:45:43 PM »
thanks
« Reply #3 on: October 08, 2010, 05:34:42 PM »
Crappie1,
Is that a 798ci Si model unit (as in an internal GPS)?
If so, call the Humminbird Customer Resource folks and tell them you want it fixed this time.  See if they will replace the whole unit since it has been back to the shop more than once.
You don’t have it mounted under anything that would block the signals from the satellites do you?
Offline crappie1
  • Unit(s): 798cisi
« Reply #4 on: October 10, 2010, 10:29:18 PM »
Thanks ...   I did talk to humminbird  firiday and they are sending me a external antenna for it  and said it should override the internal and correct my problem,  hopefully  it will.
Last post October 21, 2009, 07:29:32 PM
Last post February 18, 2012, 05:15:27 PM
by Kidott429
Last post October 25, 2010, 01:03:04 PM
by 96720
Last post February 10, 2011, 10:44:25 AM
by The bird
Last post April 11, 2011, 06:08:34 PM
by Roddy
Last post April 25, 2011, 07:06:09 PM
by Suribachi
Last post July 26, 2011, 11:23:46 AM
Last post March 05, 2014, 11:11:11 PM
by MT-ED
