Author Topic: Ethernet connection for an 899 to a 898  (Read 23930 times)
Offline lawnman53
  • Unit(s): 898si; 899hdsi
  • Software: 6.740
  • Accessories: Ethernet
« on: March 05, 2014, 01:49:58 PM »
The 898 has an ethernet port on the back, but a 899 does not. Would make an ethernet connection to the 899 with a AS EC QDE cable the same as for the 700 series? I need help!!!
When I brought the 899 unit I was told it had an Ethernet connector.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Ethernet connection for an 899 to a 898
« Reply #1 on: March 05, 2014, 02:18:07 PM »
Yes that is what you need. bob
Offline Rotus623
  • Software: 6.49
« Reply #2 on: March 05, 2014, 02:23:42 PM »
Lawnman, I bet you about crapped a brick when you went to connect those two units..... I'm glad you can connect them. I wonder why they dropped the "newer" Ethernet connections and went back to the interlink cable format.
Offline lawnman53
  • Software: 6.740
« Reply #3 on: March 05, 2014, 02:36:29 PM »
So you would spend more money, for something that will not work like it is suppose to. Lol
« Reply #4 on: March 05, 2014, 09:07:25 PM »
They are saying it is so the Ethernet connector can be part of the cable collector instead of being a separate connector.
Offline Rotus623
  • Software: 6.49
« Reply #5 on: March 05, 2014, 09:08:48 PM »
Ahhhhh, smart!
« Reply #6 on: March 06, 2014, 10:44:51 AM »
Makes it easier/faster to take on and off your boat.
Offline lawnman53
  • Software: 6.740
« Reply #7 on: March 06, 2014, 01:10:11 PM »
Greg, is my thinking correct in needing an As EC QDM ADAPTER CABLE. What about about software on both units?
Thanks in advance
« Reply #8 on: March 07, 2014, 01:37:51 PM »
That would be the AS-EC-QDE cable (not "M").
The software versions you need on both units is dependent on what software each one has now (or the software version you want it to have).
What software version does each unit have now?
« Last Edit: March 07, 2014, 01:59:22 PM by Humminbird_Greg »
Offline lawnman53
  • Software: 6.740
« Reply #9 on: March 07, 2014, 06:51:36 PM »
The 898 has the 6.4 version and the 899 has the 6.8 version. I do have the 6.7 version for the 898 but I have not updated yet.
« Reply #10 on: March 10, 2014, 12:23:42 PM »
lawman,
You will have to bring your 898 up to at least software version 6.680 for it to communicate with the 899 unit running the 6.8+ version software.  The 6.740 loaded into the 898 will work for this.
Last post March 02, 2012, 02:55:29 PM
Last post March 05, 2014, 11:11:11 PM
by MT-ED
Last post March 06, 2014, 01:11:53 PM
by lawnman53
Last post March 27, 2014, 07:26:19 PM
Last post May 27, 2014, 02:37:17 PM
Last post February 16, 2015, 07:15:36 AM
by palajam
Last post February 17, 2015, 02:37:14 PM
Last post November 20, 2024, 05:52:48 PM
by OceanAI
