Author Topic: 998C HD SI setup  (Read 12767 times)
Offline BCE
  • Unit(s): 998c HD SI , 858c HD DI
998C HD SI setup
« on: April 28, 2014, 08:35:24 AM »
Alright, I'm new here. I have done a bit of reading and I think I have my questions answered but I would like some input before I order anything. I have a 998c HD SI to mount at the rear of the boat (Lund tiller). I have a 858c HD DI to mount at the front. I am going to connect the 858 to the terrova US2. SI transducer mounted on the transom. Ethernet between the 2 units. Here is my question, I still want to mount the DI transducer on the transom next to the SI transducer. Do I want to run it directly to the 858? Could it be read through the Ethernet if connected to the 998? If I need to run it to the 858 I will need an extension to the cable, which model? I will also need a y-adapter for the transducer and us2 connection, which one supports a DI transducer or do all of them? Thanks in advance.
Re: 998C HD SI setup
« Reply #1 on: April 28, 2014, 03:09:00 PM »
Welcome to the Humminbird Side Imaging Forums BCE.
“I am going to connect the 858 to the terrova US2.”
Why not just install the DI transducer for this 858c HD DI unit to the Terrova trolling motor and forget about using the US2?
“I still want to mount the DI transducer on the transom next to the SI transducer. Do I want to run it directly to the 858?”
Yes, if you want the 858c HD DI unit to read and display the sonar data from that DI transducer correctly than you should connect the DI transducer directly to the 858c HD DI unit.
Mounting the DI transducer right next to the HDSi transducer will cause a blockage of some of the Si sonar to whichever side the DI transducer is mounted to.  If you still opt to mount the DI transducer on the transom, mount it as far to the other side of the transom as you can to minimize any blocking of the Si sonar.  Also, be advised that if both units are run at the same time that there will the chance of sonar-to-sonar interference if both units are running at the same frequency.
“Could it be read through the Ethernet if connected to the 998?”
Yes, when both units receive the 6.900/6.940 software update, but until then the answer is “No”.  When this does happen it will not work correctly as the 998c HD Si unit will treat the DI transducer as if it were an Si transducer.
“If I need to run it to the 858 I will need an extension to the cable, which model?”
That all depends on how much cable length you need.  The DI transducer comes with a 20-foot cable,  We sell 10 and 30 foot transducer cable extensions under the EC-W10 and EC-W30 part names.
“I will also need a y-adapter for the transducer and us2 connection, which one supports a DI transducer or do all of them?”
May I ask why and what you are thinking you are doing with this?
If you were to do this, the 2D sonar would come from the trolling motor while the Di sonar would be coming from the transom which I am guessing are at opposite ends of the boat.  The two types of sonar (2D and DI) will not always match up.  If your 858c HD DI unit is at the bow wouldn’t you want to know what is going on under the bow?
Offline BCE
« Reply #2 on: April 28, 2014, 04:09:18 PM »
I suppose I could eliminate all the extra parts and pieces by just installing the DI transducer on the terrova. I kinda anal retentive with fit and finish so I really didn't want zip tie the cable to the shaft. I did find a while ago someone who was able to run the transducer wire through the collar on the terrova by taking it apart. Any one else hear of this type of install?
« Reply #3 on: April 29, 2014, 11:53:46 AM »
I have but I don’t have any links to it.  Try searching this forum and if not maybe someone will post a link for you.
Offline Planokeith
  • Unit(s): Helix 12 MEGA SI Gn2, Helix 7 CHIRP Gps
  • Software: 1.61 , 1.65
« Reply #4 on: May 07, 2014, 06:56:38 AM »
 Here is Doug a Humminbird Pro staff with a you tube video on how to put the ducer cable in the groove on the terrova shaft
Tips 'N Tricks 86: Installing Side Imaging on MinnKota Terrova
Offline D S
  • Software: 7.5
« Reply #5 on: May 10, 2015, 01:00:38 PM »
what kind of glue is recommended to use in this install?
stgr
« Reply #6 on: May 10, 2015, 10:39:36 PM »
I would suggest a silicone that can be removed if ever necessary ...
Last post February 09, 2011, 07:45:17 PM
by mt72916
Last post December 23, 2011, 05:46:26 PM
by tommyboyrn
Last post August 19, 2012, 12:24:12 AM
by stratofisher
Last post May 28, 2013, 12:27:17 PM
Last post March 04, 2014, 02:20:50 PM
by Planokeith
Last post October 19, 2014, 08:57:00 PM
Last post April 02, 2015, 11:20:47 PM
Last post January 27, 2016, 11:30:58 PM
