Author Topic: 360 & 1198 antenna?  (Read 15628 times)
Offline ricqik
  • Unit(s): 2@1199, 360
360 & 1198 antenna?
« on: April 24, 2014, 08:53:35 PM »
If I used the 360 hs antenna, do I need to the 1198 antenna hooked up as well? Or does the 360 hs antenna takes the place of the 1198's antenna?
« Last Edit: April 24, 2014, 11:22:54 PM by ricqik »
Re: 360 & 1199 antenna?
« Reply #1 on: April 24, 2014, 10:19:04 PM »
Need a little more info about your installation.
Are you getting a bow or transom 360?  Where is your 1198 installed?  Do you only have the one unit on the boat?  You mentioned 1199 in the heading, but not in your text?
Offline ricqik
« Reply #2 on: April 24, 2014, 11:20:51 PM »
Oops, typo on the title. Have the 1198 on the bow, it's by itself, not linked to any other unit. The 1198 has its own external antenna. I'm adding the bow 360, but it has its own antenna, the hs antenna. As far as I can see, the 1198 has only one antenna input plug. I would assume to use the 360 hs antenna. Is that correct?
Offline N9Phil
Re: 360 & 1198 antenna?
« Reply #3 on: April 25, 2014, 08:19:37 AM »
You only need one GPS.   The GPS receiver that came with your 360 has the heading sensor so this is the one you should use.   It is my understanding that both units are the same except the one has the heading sensor that allows you to see the direction that your boat is pointed on your graph.  I look at it as I now have a spare GPS receiver if I need one.
Phil
Offline ricqik
« Reply #4 on: April 25, 2014, 08:31:31 AM »
Thanks guys. I kinda figured I don't need 2 antenna at once.
« Reply #5 on: April 25, 2014, 05:39:24 PM »
I would think this would depend on if you are going to use the HDSI xducer for chartplotting coordination...
And where that HDSI xducer is mounted...
If you are mounting the HDSI xducer to the transom and you use the bow AS GPS HS antenna from the 360...those marked waypoints (while using the HDSI)... will be a minimum of the boat length inaccurate...
If you are not going to use the HDSI at all for anything....and all marking of waypoints will be found and designated marked by the 360...the AS GPS HS antenna alone would be fine...
« Last Edit: April 25, 2014, 05:42:23 PM by rnvinc »
Offline ricqik
« Reply #6 on: April 25, 2014, 06:28:36 PM »
The hdsi will not be used since the 360 is being used in its place. Also while reading through the 360 manual, I read that it can be used as si and di. Am I reading that right.
« Reply #7 on: April 25, 2014, 07:28:10 PM »
Yes, you can get DI and SI from the 360.....where are you getting the 2D?
Offline ricqik
« Reply #8 on: April 26, 2014, 12:12:47 AM »
No 2d at the moment. This is actually my bil's install I'm doing for him. He doesn't currently have a compatible 2d transducer.
On mine, I'm running a 1199 on the bow with the 360 bow. My 2d is running off the fortrex transducer.
« Reply #9 on: April 26, 2014, 11:50:11 AM »
I think the HB unit must have, at least, a 200kHz xducer attached to obtain correct depth...(the 360 does not have a 2d piezo that I know of)...
« Last Edit: April 26, 2014, 11:52:12 AM by rnvinc »
« Reply #10 on: April 26, 2014, 03:07:49 PM »
I think Rickie is correct, the 360 requires an a seperate 2D transducer source.
Offline ricqik
« Reply #11 on: April 26, 2014, 08:07:11 PM »
Ran into an issue. Everything is hooked up, checked and double checked all wiring. Powered on the 1998 and it is not recognizing the 360. Went through the menus and nothing is highlight nor is the 360 showing up on the menu list. Waiting with plenty of times to give the 1198 time to recognize but no go after 10min or so. Retried a dozen time by powering off and restarting to no avail. Ethernet is secure.
« Reply #12 on: April 27, 2014, 05:33:36 PM »
What software version is in the 1198...??
360 requires a minimum level to operate 360...(although I'm not sure exactly which one)...
Offline ricqik
« Reply #13 on: April 27, 2014, 09:38:06 PM »
6.4* something.. I was doing a lot of reading and found out it needs 6.74 for it to be able to operate the 360. I will find out if this works.
Its too bad this info wasn't in the 360 manual.
« Last Edit: April 27, 2014, 09:39:22 PM by ricqik »
« Reply #14 on: April 28, 2014, 06:21:49 PM »
It needs to be higher than 6.57
Last post January 06, 2011, 10:54:41 AM
Last post April 10, 2013, 01:44:39 PM
by Jim Jack
Last post April 30, 2014, 09:16:26 PM
by wolfman111471
Last post August 13, 2015, 10:43:55 AM
by Gimp
Last post August 17, 2015, 02:56:54 PM
by dae06
Last post October 23, 2015, 10:50:30 PM
Last post May 08, 2018, 10:57:37 PM
Last post May 15, 2018, 11:53:21 AM
by fshndude
