Author Topic: Gps antenna for 898  (Read 12915 times)
Offline graggy
  • Unit(s): 898C si
Gps antenna for 898
« on: May 12, 2018, 06:58:02 AM »
Can anyone tell me if a humminbird gr4 gps antenna will work on a 898 unit? And what are the differences in the other humminbird pucks or antennas?
Re: Gps antenna for 898
« Reply #1 on: May 12, 2018, 09:36:04 PM »
I cannot find any documentation indicating if the AS GR4 will work with your 898  ...
I guess you could connect it and see if it shows up in the Connected Accessories view or the GPS Diagnostic view  ...
With the AS GR4 being such an older item - if would most likely not be as effective as the newer GPS antenna Accessories  ...
You could also contact HB with your question for more info  ...
1-800-633-1468
Offline fshndude
« Reply #2 on: May 15, 2018, 11:51:25 AM »
I use the high speed GPS antenna mounted on the bow. Works flawlessly.
Dave in Currituck,NC
Offline fshndude
« Reply #3 on: May 15, 2018, 11:53:21 AM »
PS I have a 899 on the console it is using a older GPS antenna with no problems. I forget just what model it is. But I know its at least 6-7 years old now.
Last post January 01, 2010, 12:03:20 PM
by John175
Last post January 06, 2011, 10:54:41 AM
Last post April 10, 2013, 01:44:39 PM
by Jim Jack
Last post April 30, 2014, 09:16:26 PM
by wolfman111471
Last post August 17, 2015, 02:56:54 PM
by dae06
Last post October 23, 2015, 10:50:30 PM
Last post May 08, 2018, 10:57:37 PM
Last post November 14, 2024, 08:12:15 PM
