Author Topic: 798 gps antenna  (Read 19703 times)
Offline gascop
798 gps antenna
« on: September 30, 2015, 01:22:59 PM »
is there a cable available to hook the 798 up to an external gps antenna ?
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
Re: 798 gps antenna
« Reply #1 on: September 30, 2015, 03:24:48 PM »
if you by the HB external GPS, the cable is with it and it is plug directly to the unit like I have done.
Offline sfw1960
  • Bringer Of The 'Bird
Re: 798 gps antenna
« Reply #2 on: October 03, 2015, 03:11:13 PM »
The AS GRP will run on an older 798ci W/ v6.300 software.
The AS HS GPS needs v 6.570 or higher so will work with the 798HD.
Both come with a 20' cable and the connector goes in the cable collector of your quick disconnect base mount.
Offline blind_sk8_16
  • Unit(s): Solix 12 SI Mega
Re: 798 gps antenna
« Reply #3 on: October 21, 2015, 11:14:36 PM »
my GPS cuts in and out (no GPS fix), instead of sending out to Humminbird and them sending back to me saying there was no problem (been reading the topics and this is what I have been seeing)... I can hook a external GPS puck to it?
Offline sfw1960
Re: 798 gps antenna
« Reply #4 on: October 22, 2015, 06:07:00 AM »
READ the previous post....
You didn't specify WHICH model 798 you had, nor software version installed.
http://www.humminbird.com/Products/AS-GRP/
Re: 798 gps antenna
« Reply #5 on: October 22, 2015, 11:01:51 AM »
While it is possible to connect an external GPS to the 798 (as outlined by Robert above) ...you should 1st investigate possible power supply issues that could be present ...
Erratic GPS function is sometimes the first signs of low or inadequate power supply caused by possible battery problems or boat wiring issues ...
« Last Edit: October 22, 2015, 11:03:07 AM by rnvinc »
Re: 798 gps antenna
« Reply #6 on: October 22, 2015, 09:44:15 PM »
sorry guys, I have the 798 ci hd si with the 7.680 software
i have tried it with fresh charged batteries and i made sure the cables are tight in the mount.
Offline sfw1960
Re: 798 gps antenna
« Reply #7 on: October 22, 2015, 10:21:25 PM »
it's the unseen, unwrapped connections that may be corroded and just may cause you trouble like Rickie speaks of.
Re: 798 gps antenna
« Reply #8 on: October 23, 2015, 10:50:30 PM »
The quick detach base mounts have been known to give some erratic power issues themselves ...
You can dis-assemble the base mount and plug the cables directly into the unit to test if there are connection issues at the head unit itself ...
Last post April 04, 2010, 08:11:21 PM
by stillbear
Last post January 06, 2011, 10:54:41 AM
Last post April 10, 2013, 01:44:39 PM
by Jim Jack
Last post April 30, 2014, 09:16:26 PM
by wolfman111471
Last post October 20, 2015, 08:21:38 AM
by tstorm87
Last post May 08, 2018, 10:57:37 PM
Last post May 15, 2018, 11:53:21 AM
by fshndude
Last post November 14, 2024, 08:12:15 PM
