Author Topic: Files on the SD card  (Read 17194 times)
« on: February 03, 2010, 04:50:32 PM »
After I've made a few recordings and a few snapshots onto the SD card.....
I put the SD card in  my pc and see the following on my SD card.....
Record (folder)
Snapshot (folder)
Profille.txt (text document in notepad)
Does the "Profile.txt" document have to stay in the same directory as either/both of the folders for the info in the folders to work correctly in my viewer programs....??
Re: Files on the SD card
« Reply #1 on: February 03, 2010, 07:38:44 PM »
No, the profile does not have to be copied over.  It is just unit info and is updated and stored when you have the sd card in.
You can use the profile.txt to customise your startup screen.
« Reply #2 on: February 04, 2010, 09:08:48 AM »
If I want to re-insert the SD card back into my 1197 unit and view the snapshots/recordings on the 1197 unit...
Does the Profile.txt have to be on the SD card along with the "Snapshot" folder and the "Recording" folder in order for the snapshots and recordings to function properly on the 1197 unit...??
Offline trixter
  • Unit(s): 595c
« Reply #3 on: February 04, 2010, 09:28:26 AM »
I have a 595c.  I have read the instructions many times and I know and understand how the F/F works, however could you lay out a scenario for me, or check mine.  Launch, turn on f/f use all the time, then at the dock again, save Nav. data; and at home download data onto a SD card and then upload to computer and then I can review tracks, way-points etc., then do I delete all Nav. data, and start fresh?  Or do I want to save some of the Nav. data; ie, way points?   I thought I had this all working properly, but now I am confused about the 'Delete all Nav Data'
Thanks for your help.
« Reply #4 on: February 04, 2010, 10:03:09 AM »
I hope someone will chime in if I get this wrong...
Waypoints, routes and tracks are automatically saved into the FF unit's internal memory...
When you want to use that info in your home pc....you have to "Download" that info from your unit onto the SD card so that, now,  you have 2 copies of the info...1 on the FF unit...and 1 on the SD card....
The info that you now have the SD card can be used in your pc in Hummingbird PC to manage the waypoints, routes and tracks...
The info that is still in your FF unit will stay there until you decide "if" you want to get rid of it by "Deleting all NAV Data" in the menu system...
It's a good idea to keep a copy of this data on your pc in case the info gets erased from your FF unit when you do a software update...
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #5 on: February 04, 2010, 12:59:46 PM »
Excellently learned RNVINC, I bow in respect!  ;)
Now it's your turn to help a humble German out:
What on earth is a "F/F"???
Regards / Harry
YES,......
WE SCAN!
« Reply #6 on: February 04, 2010, 05:26:14 PM »
Regards / Harry
I've seen "FF" in other forums when talking about a fish finder...
I, myself don't believe there is such a thing as a fish finder....lol......unless ,of course we're talking about birds of prey...they can find fish..... ;D
My "FF" only tells me what it "thinks" is a fish.... ;D ;D ;D
Offline Jolly Roger
  • HB Addicted
« Reply #7 on: February 04, 2010, 10:00:49 PM »
F/F is fish finder? :o
Well... I think I should have come to this without help  :-[.
Thanks for advice!
Harry
YES,......
WE SCAN!
Last post March 09, 2010, 06:49:33 PM
by Llunker
Last post May 06, 2012, 09:33:25 AM
by slabbandit
Last post August 03, 2015, 09:13:16 PM
by Beaulieu80
Last post July 22, 2015, 01:44:15 PM
Last post June 22, 2017, 10:40:37 AM
by 35wailin
Last post April 11, 2021, 11:36:17 AM
by William Rodney
Last post November 17, 2023, 01:25:24 AM
by navionic
