Author Topic: A few questions re: AC and files on card  (Read 9215 times)
Offline 35wailin
  • Unit(s): Helix 7 SI
« on: June 15, 2017, 11:06:28 AM »
1) is it worth archiving raw data that is on the card after recording session prior to processing and saving as a map?
2). Can the raw data be deleted from the card after it is processed and saved onto the map?
Offline D S
  • Software: 7.5
Re: A few questions re: AC and files on card
« Reply #1 on: June 16, 2017, 11:41:20 AM »
wallin ,
1 you should always back up your data....computers/hard drives fail or if you get different software you will have the data saved.
...I would back it up after processing as well then you have both in case of a disaster.
2 yes if you do a search in the auto charts forum
 .....it says what files you can delete  recordings...but dont delete lakemaster files on your zerolines card  or it will be useless.
These files are critical to the process for creating maps.  Do not delete the LkMaster folder from your ZeroLine Map Card.  There is a $19.95 fee to cover shipping, handling and maintenance to rewrite these files in the event of user error.
at some point you may have to make room  as zerolines cards will eventually fill up
ds
stgr
Offline D S
  • Software: 7.5
« Reply #2 on: June 16, 2017, 11:43:43 AM »
wallin ,
 if you look on the forums under autocharts,,
 Camohunter has made a great tutorial file as well this should answer most questions u may  have
ds
stgr
Offline 35wailin
« Reply #3 on: June 22, 2017, 10:40:37 AM »
OK, thanks guys.
Last post February 04, 2010, 10:00:49 PM
Last post March 09, 2010, 06:49:33 PM
by Llunker
Last post May 06, 2012, 09:33:25 AM
Last post April 03, 2015, 06:03:07 PM
by Tigersix
Last post July 22, 2015, 01:44:15 PM
Last post July 04, 2016, 11:04:13 PM
by JiMinneye
Last post April 11, 2021, 11:36:17 AM
by William Rodney
Last post November 17, 2023, 01:25:24 AM
by navionic
