Author Topic: ALL SI Models - GPS receiver pigtail connector  (Read 13668 times)
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« on: February 02, 2010, 03:02:14 PM »
Model:
ALL GPS Models
Suggested Upgrade:
Explanation:
Having the GPS receiver's pigtail wires equiped with a female NMEA COM connetor would enable NMEA output to PC / Laptop on the water. Currently one has to splice a cable to the pigtail wires. That means either cutting the NMEA COM connector off of an ASPC2 cable or getting a RS232 cable and start fiddling around with that. If a female NMEA COM connector is attached to the pigtail one can plug in the ASPS2 pc connection cable and is ready to go for outputting NMEA data on the water AND still can use the ASPC2 cable at home for updates / downloads etc.
Added in Software Version:
Comments on Update:
« Last Edit: February 02, 2010, 03:08:11 PM by Jolly Roger »
YES,......
WE SCAN!
Offline keizerh
  • Unit(s): none
Re: ALL SI Models - GPS receiver pigtail connector
« Reply #1 on: February 02, 2010, 03:57:06 PM »
I Would like to keep it as pigtail, so I kan easily connect my VHF and NMEA Multiplexer to it.
Hendrik
Offline Jolly Roger
  • HB Addicted
« Reply #2 on: February 02, 2010, 04:31:18 PM »
Good point too Hendrik.
So I suggest a female NMEA COM connector plus a male NMEA COM connector with bare wires for Hendrik and others who have more equipment to hook up.
Regards / Harry
YES,......
WE SCAN!
« Reply #3 on: February 02, 2010, 04:59:59 PM »
why not have a pigtale connector to the pigtale to do that which is wanted.  chuck
Offline keizerh
  • Unit(s): none
« Reply #4 on: February 02, 2010, 05:00:31 PM »
I am not to demanding
DB9 Com to Nmea2000 with mico-C or simnet is also okay.
Hendrik
Offline keizerh
  • Unit(s): none
« Reply #5 on: February 02, 2010, 05:03:17 PM »
Such as this?
« Reply #6 on: February 02, 2010, 06:01:10 PM »
Harry,
After our discussion this morning I would have to agree.  Have a NMEA plug coming off the GPS and then have a connector with pigtails, or connector with DB9, pc connect cable, etc.
Offline George
  • Software: Always up todate
« Reply #7 on: February 02, 2010, 09:38:54 PM »
This will give us the best of both worlds
Offline Jolly Roger
  • HB Addicted
« Reply #8 on: February 25, 2010, 05:39:18 PM »
Another though on this one which came up on my mind:
If we could have a female connector to the pigtail, it would be even better to have the pigtail equipped with the fourth (green) wire.
Then we could send data to the unit on the water like modified waypoints or routes created in HumminbirdPC without disconnecting and reconnecting the ASPC-2 and GPS cable.
I don't know if this would work or if this would creat problems with the GPS receiver, but as far as I understood, the unit will go in "PC connect" mode as soon as it detects HumminbirdPC.
My 2 cents.
Regards / Harry
YES,......
WE SCAN!
Offline soretoe
« Reply #9 on: February 25, 2010, 06:23:45 PM »
All this talk about pig tails is making me hungry for some BBQ ;D
Freedom isnt free, if you want to know the real cost visit a national cemetery or VA Hospital.
I can also be found at;
http://allatoonabass.proboards.com/
Last post February 13, 2013, 05:18:18 PM
by short grub
Last post March 11, 2014, 11:25:48 AM
Last post May 11, 2015, 11:42:13 PM
Last post July 13, 2015, 12:20:48 PM
by Free2Fish
Last post January 04, 2016, 11:23:27 PM
by 49thdiver
Last post May 25, 2016, 08:26:53 PM
Last post June 29, 2017, 03:36:49 AM
by Rüdiger
Last post April 26, 2018, 08:43:57 AM
by Woollybob
