Author Topic: 997c si P900 Connector Pinout  (Read 10114 times)
Offline 49thdiver
  • Unit(s): 997, wide 1
« on: January 04, 2016, 02:41:21 PM »
Hi any one have a pin out description for the P900 connector on the main board.
I had to replace the 7 pin connector years ago as it did not stand up in my environment with the frequent plug and unplug cycles I was subjecting it to. I am replacing the SI transducer again this time I am making an adapter between the standard HB cable end and my waterproof 9 pin connector so save me cutting the new transducer cable. I just want to confirm that I have all the pins wired correctly internally on the WP connector, looking at it again it looks like the orange and brown are switched.ila_renderedila_renderedila_rendered
With thanks
Re: 997c si P900 Connector Pinout
« Reply #1 on: January 04, 2016, 10:28:35 PM »
Holy moly diver ...
And I thought rewiring xducer cable was intense ... I can't imagine rewiring to the internal board ...
Although I don't have the pinout for the wires from the connector to the board ...here is the pinout for the HDSI xducer cable connector ...
Offline 49thdiver
« Reply #2 on: January 04, 2016, 11:23:27 PM »
Holy moly diver ...
Heh thanks Rickie, I have this drawing it's the other side of the connector that I failed to document properly that goes to the main board.
It's funny how it goes when you start hacking into these things, I installed it on the boat a year ago and noted that the SI seemed to be reversed. I simple switched the cable connections around and kept going. Of course my memory is not so good on the details. So now that I am replacing the xducer and do not want to cut the cable I am looking at it more carefully to make a short adapter pigtail and want to get it right the first time(or second time). It looks like I switched two wires by accident inside the plotter. So I just need the wire colors on the inside of the connector to confirm my assumptions. The wires are not the same colors on the inside. Yea I did the original mod out of desperation, the original connector just got to be totally unreliable and the service center in Vancouver was not helpful. I have built a tow from a salvaged xducer that I want to connect to the system as well which is also the reason to upgrade to a much better  connector.
If anyone even had a photo of the back side of the connector showing the colors of all the connections that would help !!
Thx everyone for looking.
« Last Edit: January 04, 2016, 11:39:12 PM by 49thdiver »
Last post August 20, 2009, 04:00:01 PM
Last post February 25, 2010, 06:23:45 PM
by soretoe
Last post March 21, 2010, 01:22:53 PM
Last post February 13, 2013, 05:18:18 PM
by short grub
Last post March 03, 2014, 05:47:30 PM
by N9Phil
Last post July 13, 2015, 12:20:48 PM
by Free2Fish
Last post April 26, 2018, 08:43:57 AM
by Woollybob
Last post June 15, 2023, 08:42:09 PM
by Bluegill11
