Author Topic: 788 di depth problem  (Read 8343 times)
Offline chompin
  • Unit(s): 788 di
  • Software: 6.4
« on: September 07, 2013, 12:45:39 PM »
Excellent works up to 200 feet
Over 200 shows no bottem the display turns to somting like surfes cluster
When I get back to work below 200 it returns to show exlant display
Re: 788 di depth problem
« Reply #1 on: September 09, 2013, 04:09:51 PM »
Welcome to the Humminbird Side Imaging Forums chompin.
Was this is fresh or salt water?
Was there another sonar unit running on the boat at the same time?
What is the unit showing as the voltage?
Offline chompin
  • Unit(s): 788 di
  • Software: 6.4
« Reply #2 on: September 10, 2013, 02:31:51 AM »
no other unit in boat
salt water
volteg 12.1
could it be transduser angale not install correctly ?
thanks ..
« Reply #3 on: September 10, 2013, 11:28:38 AM »
I think that the angle of the transducer would have to be off quite a bit as the DI sonar has been found to work down to 350 feet in fresh water, I don’t know what its salt water limit is.
Is the transducer mounted on the outside of the hull or is this an inside-the-hull mount?
Check your software version in your 788ci DI unit.
Also see if you have the “Digital Depth Source” menu (you may have to be in the “Advanced” User Mode to see it).
Offline chompin
  • Unit(s): 788 di
  • Software: 6.4
« Reply #4 on: September 10, 2013, 11:41:13 AM »
the transduser  mount is outside
I have the latest soft update
« Reply #5 on: September 10, 2013, 12:13:54 PM »
That may be the limit of the DI sonar in the salt water you are in - but I do not know that for sure.  Try the Digital Depth Source menu and see if it will read deepr with the 2D sonar.
Last post April 06, 2010, 03:38:06 PM
by Chiboo
Last post March 09, 2011, 11:47:15 PM
by muskyhunter
Last post April 22, 2011, 11:04:47 AM
by Roddy
Last post August 12, 2011, 09:25:00 AM
by jimf
Last post July 17, 2012, 04:00:54 AM
by Rüdiger
Last post September 04, 2012, 12:46:05 PM
Last post April 29, 2013, 04:20:47 PM
by magan863
Last post May 28, 2013, 10:36:37 AM
