Author Topic: 998 Track Errors  (Read 14345 times)
Doc Stressor
  • Guest
998 Track Errors
« on: August 24, 2013, 11:56:14 AM »
I've recently had a puzzling problem with my 998, which is just over a year old. The problem is 2-fold:
1. When I restart the unit, my recent tracks are often incomplete and displaced by several miles. Since I'm running between known way points, the displacement to areas of the chart with no way points is very apparent. When I export to Humminbird PC, the same displacement is seen when I view in Google Earth.
2. After I export all data to the SD card, I routinely go back and delete all navigation data using the usual command. However, when I reinstall my way points from the SD card after deleting the tracks in Humminbird PC, some of the older tracks still appear as dashed lines on the chart.
Any ideas about this problem? Is there someway to reformat the memory registers on the unit to be sure that all of the old data is removed?
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: 998 Track Errors
« Reply #1 on: August 25, 2013, 12:05:03 AM »
I would call HB Support first!
But you might have corrupted navdata in your 998, and I would Format the Nav Directory.
<menu><menu>, select Reset Tab, select Format Nav Directory.
Then reload navdata from HBPC after setting the Saved Track Defaults to the track characteristics most common desired, then edit those tracks if or when different characteristics are needed.
I use the Bold Line, then different track colors(roadbeds=black, creeks=blue, boat-runs=green).
What software levels is your 998 and HBPC?
« Last Edit: August 25, 2013, 12:26:25 PM by LittleGazoo »
Offline LittleGazoo
  • Software: 3.640
« Reply #2 on: August 27, 2013, 12:22:32 AM »
FYI: Around software level 5.500 released around early 2011, HB did fix a phantom track problem.
Last post June 23, 2012, 09:19:22 PM
by ClemsonBloz
Last post April 26, 2014, 06:51:19 PM
by ricker
Last post July 22, 2014, 05:47:32 PM
by DiveExplorer
Last post April 05, 2015, 11:17:01 AM
by nwifishnut
Last post March 07, 2016, 01:22:32 PM
by bobcoy
Last post November 06, 2020, 09:35:56 PM
by LittleGazoo
Last post April 03, 2024, 08:18:36 PM
