Author Topic: 581i HD Track problem  (Read 9727 times)
Offline DiveExplorer
« on: July 22, 2014, 02:34:21 PM »
Hi All
I own 581i HD Di unit which I´m using to collect gps and depth data.
I was mapping a area few days ago. I was trying to map the area pretty well and thorough.  All seems to be fine, gps was working well, the sonar was collecting depth very well also.
Then afterwards I exported all navigation data to an SD card.  But when I was going to check it on the computer there was nothing, no tracks from that day.
There were old data from another day and area. When I plugged the transducer and got a gps fix again I could se that the breadcrumbs from the area was still there. I tried to export it again, and it worked. But there was no depth data only gps data.
Have somebody else run into some similar problem ? Is there something that I can do ? Or is this something that I can expected ?
Re: 581i HD Track problem
« Reply #1 on: July 22, 2014, 02:44:41 PM »
Did you remember to Save Current Track when you were finished before shutting your 581i HD DI unit off?
« Reply #2 on: July 22, 2014, 03:08:48 PM »
That is something that I´m not sure about. There is a possibility that I did not do that.
Could that explain that I have the track but no depth data ?
« Reply #3 on: July 22, 2014, 04:13:34 PM »
Yes and it will also explain why there was no track data when you originally exported it.
« Reply #4 on: July 22, 2014, 05:47:32 PM »
Ok thanks,  :) then I know whats the problems is..... Me...  :o
Better to practice more on this unit.  8)
Last post August 15, 2010, 05:53:03 PM
by tennwalkinghorse
Last post September 23, 2010, 07:56:42 AM
Last post April 15, 2013, 02:45:25 PM
Last post August 27, 2013, 12:22:32 AM
by LittleGazoo
Last post February 03, 2014, 04:54:56 PM
by JD88
Last post November 06, 2020, 09:35:56 PM
by LittleGazoo
Last post April 03, 2024, 08:18:36 PM
