Author Topic: 1198 & 998 Cable Collector  (Read 6573 times)
Offline ezfishn
« on: August 24, 2013, 09:50:06 AM »
I have a 1198 at console and 998 HDSI at bow and wondering if I can swap locations without changing the wiring?  The cables appear to be the same but the collectors are different.  Is it possible to just swap the collectors or can they be removed?  Thanks
Re: 1198 & 998 Cable Collector
« Reply #1 on: August 24, 2013, 10:17:10 AM »
Assembling the collectors with the various cables in the correct slot can take a person with 3.5 hands working together...tedious at best...
The collectors can be removed ...but it may cause intermitant connections...(the HB connector design of all their cable ends are designed poorly for trouble free connection points)...
I only have the one 1197. ...but I do not use the collector because of the amount of testing different scenarios of xducer's with various cables...
I have adjusted the pins in nearly all of my cable connector ends to create more friction where the pins insert into their opposing female pin slots...
Bending the pins "ever so slightly" helps....but be warned...THE PINS BREAK OFF EASILY...
« Last Edit: August 24, 2013, 10:24:36 AM by rnvinc »
« Reply #2 on: August 30, 2013, 01:38:40 PM »
The cables are the same, it’s just the cable collectors that are different.  They may be swapped if needed.
Last post June 28, 2014, 08:39:09 PM
by jrapose
Last post July 13, 2013, 06:51:56 AM
Last post March 05, 2012, 12:46:10 PM
Last post July 05, 2012, 03:16:10 AM
by Rüdiger
Last post August 07, 2012, 05:45:16 PM
by Paul D
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post April 15, 2013, 12:51:21 PM
Last post April 28, 2014, 01:18:26 PM
by nwifishnut
