Author Topic: 'Y' Cable  (Read 16892 times)
Offline rockdog23
  • Unit(s): 998C SI
'Y' Cable
« on: May 13, 2010, 12:09:56 PM »
I hooked up my transducer to the Y cable now I cannot get them apart, is there a trick to it?
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: 'Y' Cable
« Reply #1 on: May 13, 2010, 02:15:19 PM »
Hello Rockdog and welcome to the forum!
The Y-cable connectors have two "noses" while the the transducer connector has two "gaps" where the noses fit in. I suggest you take a hair dryer and gently heat up the connector to give the plastic a bit more flexibility to let the noses slip out of the gaps.
Whatever you do: Do NOT pull on the cables, no matter how tempted you are to get a better grip.
Hope this helps!
Regards / Harry
YES,......
WE SCAN!
Offline jrapose
Re: 'Y' Cable
« Reply #2 on: June 26, 2014, 07:38:27 PM »
I also have a problem with the Y connector...  I can't get the connector to slide in...  the connectors match up perfectly but just won't lock together...the Y connector that goes into the unit appears to lock in, but the transducer plugs just won't go into the female  connector ends.  I just bought some dielectric silicone and that might make it work..
My boat has a deep hull and hopefully by using two transducers I will get a cleaner picture.
Joel
Re: 'Y' Cable
« Reply #3 on: June 27, 2014, 09:57:15 AM »
Welcome to the Humminbird Side Imaging Forums Joel.
If the hair dryer or dielectric grease does not help, just contact the Humminbird Customer Resource Center folks about getting the y-cable replaced.
Offline jrapose
Re: 'Y' Cable
« Reply #4 on: June 28, 2014, 08:39:09 PM »
The silicone grease worked.,...still was a pain to get the plug into the socket but it worked and now there is not a shadow  (hull) in the picture.
Thanks Again
Joel
Last post October 27, 2011, 07:46:29 AM
by bigkahuna
Last post July 26, 2011, 11:23:46 AM
Last post August 10, 2011, 10:46:27 PM
Last post August 17, 2011, 06:14:43 AM
by Angry
Last post July 13, 2013, 06:51:56 AM
Last post April 22, 2012, 01:03:24 PM
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post November 03, 2014, 09:41:00 PM
