Author Topic: Cat. cable  (Read 16177 times)
Offline Rüdiger
Cat. cable
« on: July 01, 2012, 03:38:12 AM »
Hi all
What type of cat. Cable you use?
Patchcable or installationcable?
mvh
Rüdiger
Finding is better than losing
Offline Roddy
  • Scan,scan and rescan
Re: Cat. cable
« Reply #1 on: July 01, 2012, 11:09:21 AM »
Rudiger, The last two tow fish I have with CAT8 cable.
              Broader band with and 1750 lbs braking strength so there is no need for a steel cable which makes life better!
Enjoy Roddy
« Last Edit: July 01, 2012, 11:32:30 AM by sonar2000 »
Scan,Scan and Rescan Roddy
Offline kron
  • Unit(s): 997c SI
Re: Cat. cable
« Reply #2 on: July 01, 2012, 03:45:01 PM »
I use patch cable, because it is not so stiff as the installation cable.
Daniel
Offline Rickard
Re: Cat. cable
« Reply #3 on: July 02, 2012, 05:17:26 PM »
Roddy,
Do you mean this cable: http://www.singlepointnetworks.co.uk/cat8cable.asp ? Do they specify a break load or have you tested that yourself? What makes this a siamese cable?
Rickard
Offline Roddy
Re: Cat. cable
« Reply #4 on: July 02, 2012, 06:36:55 PM »
Rickard, Yes and the spec sheet states 1750 lbs test.
I hung the tow fish in a wk mine sweeper,had to work it free and had no damage to the cable and a few dings to the fish.
Roddy
Offline flo
  • Unit(s): 1198c SI, ROV with USBL Tracking
  • Software: 6.490
  • Accessories: DrDepth, Rotational Device
Re: Cat. cable
« Reply #5 on: July 04, 2012, 09:32:53 AM »
Hi Roddy,
I have been in contact with Paul Gillett from singlepoint networks. He wrote me the cable they use is manufactured by Leoni Kerpen in Germany, and therefore I should better buy it in germany directly to avoid shipping costs. The Leoni type numer is 7KS800001. Normaly the type number and the type (MegaLine G12-150) is printed on the cable - perhaps you could confirm?
I took a look into the spec sheet and found something confusing - this type of cable is only allowed for a maximum of 130N (13kg, about 30lbs) tensile load?
Since I'm very interested in a single cable for an affordable price with that strength you posted below you could perhaps give some more information on your cable?
Thank you very much.
Best regards,
Flo
Watch out where the huskies go, and don't eat that yellow snow
Offline Rüdiger
Re: Cat. cable
« Reply #6 on: July 05, 2012, 03:16:10 AM »
A cable is no rope at which it arrives at the ultimate load.
If a cable is important to the max. tension in the long run it can tolerate without damage.
mvh
Rüdiger
Last post June 28, 2014, 08:39:09 PM
by jrapose
Last post July 13, 2013, 06:51:56 AM
Last post March 05, 2012, 12:46:10 PM
Last post August 07, 2012, 05:45:16 PM
by Paul D
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post October 29, 2012, 04:13:20 PM
Last post December 06, 2012, 11:56:16 AM
by Consigliere
Last post November 03, 2014, 09:41:00 PM
