Author Topic: Need to verify that the cable I need to connect a second  (Read 8581 times)
Offline maachuu
  • Unit(s): 898si -998c HD SI - Piranha Max 150
« on: July 03, 2013, 10:17:28 PM »
transducer to my 898 is the AS-SI-DB-Y. Will be connecting the SI ducer that came with the 898 and a XNT-9-20-T, so that I can mount the XNT-9-20-T lower on the transom to try and get depth reading while on plane at speed. Just wanted to make sure before I ordered
thanks
maachuu
ASAP - Always Say A Prayer
Offline maachuu
Re: Need to verify that the cable I need to connect a second
« Reply #1 on: July 03, 2013, 11:24:06 PM »
after more research and reading, I have ordered the AS-SI-DB-Y cable, it is what I need to do the job I do believe :)
« Reply #2 on: July 04, 2013, 11:25:04 AM »
Here is good info on installing the shoot thru hull xducer...
Be sure and test the install spot before epoxying...
http://www.bbcboards.net/humminbird-sonar-gps/172972-installation-networking-information-resource.html#post1538600
Last post January 30, 2010, 04:23:31 AM
Last post February 24, 2010, 01:11:57 AM
by legend
Last post June 06, 2013, 04:12:44 PM
Last post March 03, 2014, 03:27:12 AM
by Rüdiger
Last post August 12, 2014, 08:50:55 PM
by whosmatt
Last post February 09, 2016, 01:34:58 PM
Last post May 12, 2016, 09:27:33 AM
by bigterp
Last post June 02, 2020, 11:08:31 PM
by 6speedy3
