Author Topic: 998 won't connect to gps etc.  (Read 9946 times)
Offline 6speedy3
  • Unit(s): 788ci;998si
« on: April 22, 2020, 05:45:52 PM »
Hi, I brought my 998 in the house last winter and used in simulator mode to learn and relearn stuff. I have put it back in the boat and now it won't hook up to gps, sonar etc only thing it shows working is the temperature. Any thoughts as to what is going on what the fix might be. Thanks in advnance.
Re: 998 won't connect to gps etc.
« Reply #1 on: April 22, 2020, 09:52:47 PM »
Are you outside where the GPS can see the satellites?
The unit will not show Chart views, Chart menus, or Nav menus until it connects to the orbiting satellites (in Normal operating mode)  ...
Offline 6speedy3
« Reply #2 on: April 23, 2020, 01:03:13 PM »
I pulled the boat out in the driveway same thing. Except, I deployed the terrova and now the temp and i-pilot link are connected????
« Reply #3 on: April 24, 2020, 02:08:24 AM »
Try Restore Defaults under the Setup tab  ...
If that doesn’t work - do you know anyone with a HB unit you can test on your xducer and GPS antenna?
Offline hoselrocket
  • Unit(s): 997csi
  • Software: 4.75
  • Accessories: barometer
« Reply #4 on: June 02, 2020, 11:00:22 PM »
I have a 997C SI that just lost the GPS and chart this spring after being stored all winter.  The unit wont connect to GPS but the sounder works.
Offline 6speedy3
« Reply #5 on: June 02, 2020, 11:08:31 PM »
The AS GR50 module is bad on mine. I have two 998's both units work fine of the gps module on the bow. I have ordered a AS GRP Precision module.
Last post January 30, 2010, 04:23:31 AM
Last post February 24, 2010, 01:11:57 AM
by legend
Last post April 17, 2012, 03:06:14 AM
by xSilmarilSx
Last post March 23, 2013, 07:25:47 PM
by zwhits
Last post May 02, 2013, 10:45:13 AM
by bsmith
Last post June 06, 2013, 04:12:44 PM
Last post July 04, 2013, 11:25:04 AM
Last post May 12, 2016, 09:27:33 AM
by bigterp
