Author Topic: Humminbird PC Connect Cable to setup NMEA  (Read 10689 times)
Offline Batram
  • Unit(s): 898 C / 858 HD DI C / 587CI
« on: March 02, 2014, 12:10:52 PM »
I have an 898 Humminbird and have been using DrDepth for a couple of years with the SD card but now, I want to use a P.C. and setup NMEA.  I have searched both DrDepth and Humminbird but cannot find what cable to use and how to exactly to set this up.  I would appreciate any help setting this up?
Offline Rüdiger
Re: Humminbird PC Connect Cable to setup NMEA
« Reply #1 on: March 03, 2014, 03:27:12 AM »
Hi Batram
Welcome to the forum :)
If you have DrDepth SS, so you can connect your 898 via ethernet cable to the PC (description of itself make the cable you can find in the help function of DrDepth). Otherwise, you can use the NMEA output (pictail) on your unit, plus there are several of answer precisely postings. Just use the search function of this forum.
mvh
Rüdiger
Finding is better than losing
Last post January 30, 2010, 04:23:31 AM
Last post May 24, 2018, 10:13:38 PM
by Gimp
Last post May 22, 2013, 01:36:53 PM
by promapper
Last post July 04, 2013, 11:25:04 AM
Last post March 24, 2015, 12:54:20 PM
Last post May 12, 2016, 09:27:33 AM
by bigterp
Last post January 17, 2017, 11:37:14 AM
Last post May 03, 2019, 01:00:49 AM
by DennyO
