Author Topic: False depth reading  (Read 6706 times)
Offline iceimanhunting
  • Unit(s): 898c SI
  • Accessories: NONE
False depth reading
« on: June 21, 2013, 02:53:17 PM »
I have a 898SI  while fishing in 190 ft of water the unit was reading 70 ft of water.I tried shutting the unit down and restarting the unit and got the same70ft reading.I shut the down again and unplugged the back and plugged the back in again same reading.Then restored defaults and the unit read correct depth..
Re: False depth reading
« Reply #1 on: June 21, 2013, 04:10:29 PM »
iceimanhunting,
Welcome to the Side Imaging Forums.  Sorry that you first post has to be about a problem.
Was there another sonar unit running on the boat at the same time?
Was there a strong thermocline at about the same 70 foot water depth?
After you reset the unit did it keep reading the correct depth or did it start reading 70 feet deep again?
  • Unit(s): 898c SI
  • Accessories: NONE
« Reply #2 on: June 21, 2013, 08:21:36 PM »
First,I love this unit,there was no other unit running and when I restored defaults it read the correct depthright away.
Offline sjefsrafsern
    • neptune og nemo`s fiskeside
  • Unit(s): 898/1198
  • Software: 6.740
  • Accessories: digitroll 5 ts cannonlink
« Reply #3 on: June 23, 2013, 12:39:39 PM »
hi, next time this happens try to set your 2d to 200 feet or a littlebit below the actual depth, quite often this is the only way to get correct depthreadings.  :)
Offline V Side Down
  • Unit(s): 898c SI
  • Software: 6.460 ?
« Reply #4 on: August 02, 2013, 02:41:50 PM »
I had same issue recently. Which coincidentally was the first time out after having installed and uninstalled 6.40? the trip before.
Last post June 23, 2010, 09:24:55 PM
by reelman
Last post June 11, 2010, 08:42:41 PM
by majflyboy
Last post October 31, 2012, 03:42:56 PM
Last post October 11, 2013, 11:24:37 AM
Last post April 16, 2014, 12:04:58 PM
Last post May 07, 2014, 10:28:16 AM
Last post May 29, 2014, 08:41:20 AM
Last post October 25, 2015, 11:07:48 AM
by fishbone
