Author Topic: water in the display  (Read 10680 times)
Offline marlin23
  • Unit(s): 997 si co
« on: June 16, 2013, 02:36:48 PM »
I noticed that the display on the sides there is water. how can I fix it?
Re: water in the display
« Reply #1 on: June 18, 2013, 12:40:13 PM »
That's a tough one.
I'd call Humminbird's customer service and ask their advise.
It may be a simple matter of loosening some screws and letting
the water out, but that may void your warranty.  Also, you may
have a defective seal on the unit which probably needs replacing.
If your unit is under warranty, ask for a pre-paid address label,
if they want you to ship the unit to them.
« Reply #2 on: June 18, 2013, 01:34:50 PM »
Is the water actually under the lens (the clear glass area over the display) or is it to the sides of it?  I ask because the lens is sealed to the front housing of the unit and there is a snap on bezel that fits over it that can have water in it that does not get to the actual inside of the unit.
If it is truly inside the unit there is nothing that you can really do for it except to send it into a service center to be fixed.  Simply getting the water out will not fix it as you will not know how the water got into the unit to begin with and it will just leak in again.
Offline marlin23
« Reply #3 on: June 18, 2013, 03:26:42 PM »
hello, water is located at the sides of the display. and is no longer in warranty. I find it strange that it is not hello, water is located at the sides of the display. and is no longer in warranty. water resistant. if it is sent in how much would it cost assistance.
« Reply #4 on: June 19, 2013, 01:14:29 PM »
You would need to check with your local service center for that information.
Offline matt@reefmaster
  • Unit(s): 997
  • Software: 4.75
« Reply #5 on: June 19, 2013, 01:22:00 PM »
Hi Marlin,
It sounds very much like something that happened to my 997. I wasn't sure that it was water - it was a kind of bubbling effect at the edges of the glass, as if the screen itself was delaminating. I lived with it for a couple of years (it didn't really impede the display), and then finally (once my GPS, Transducer and power connections were all failing) I sent the whole unit back for the fixed price out-of-warranty repair. Can't fault the service for a 6-7 year old unit - I think when it came back the only original item left was the front of the case. It's a new machine!
matt
Offline marlin23
« Reply #6 on: June 20, 2013, 06:04:16 AM »
hello, matt,
actually yesterday I partato the unit to a repairman to show it, and he confirmed what you said and ciaoč that it is not water but liquid found in the unit and that these should be the subject after a while. I'm not under warranty you hamm it repaired under warranty? I can siegare what should I do? or should I use finquando does not die?how much it cost to bring the unit under warranty? my I have bought about quatteo years ago.
Last post March 14, 2010, 05:33:55 PM
by Chiboo
Last post February 20, 2014, 09:56:43 PM
Last post May 16, 2014, 12:24:55 PM
Last post April 28, 2015, 04:22:12 PM
Last post February 14, 2017, 12:35:25 AM
by hayabusaracer
Last post April 25, 2017, 10:47:15 AM
by FloorBoss
Last post November 13, 2019, 10:00:23 AM
Last post August 31, 2023, 09:05:29 PM
