Author Topic: Need help with Humminbird Onix display  (Read 12121 times)
Offline hayabusaracer
  • Unit(s): Humminbird Onix 8SI
« on: February 12, 2017, 07:14:43 PM »
I bought a new Humminbird Onix 8 touch screen a couple months ago. I've had it out on the water at least 6 times and it had worked great until yesterday. I powered it up and could barely see the screen display. I can only barely see it if the sun is shining directly on the display. I checked voltage with it off and with it on at the factory power cord. 12.68 both on and off. It is wired with 8 gauge power and ground wire back to starting battery. The brightness is turned all the way up. I brought it back home and powered it up with an external power supply and a different power cord I bought so I could play with it at home. It had the same problem. Does anyone have any ideas on this? I will call Humminbird tomorrow but I just wanted to make shure I wasn't overlooking anything first. I have examined the pins on the unit and they all appear to be straight.
Re: Need help with Humminbird Onix display
« Reply #1 on: February 12, 2017, 08:28:09 PM »
After the unit fully boots into Normal or Simulator - press the power button 1 quick press to bring up the power Xpress menu ...
Make sure "Night Mode" is not turned on ...
« Reply #2 on: February 12, 2017, 08:33:29 PM »
When I do that the screen goes completely dark. I tried it in a dark room but that doesn't help. The only way I can see anything is if I shine a flashlight on the screen.
« Reply #3 on: February 12, 2017, 08:36:26 PM »
I tried using the HDMI connection to display on my TV but that didn't work either. The TV never recognized it.
« Reply #4 on: February 13, 2017, 09:06:49 AM »
Sounds like time to call HB ...
1-800-633-1468
« Reply #5 on: February 14, 2017, 12:35:25 AM »
I called them this morning and was told to send it in. Hope to get it back soon.
Last post December 25, 2009, 12:38:46 PM
by harry padgett
Last post January 08, 2014, 10:33:08 PM
by Nitro78
Last post April 25, 2014, 12:54:28 PM
Last post April 28, 2014, 03:18:58 PM
by aholzhausen01
Last post September 07, 2015, 07:09:16 PM
by LittleGazoo
Last post April 15, 2015, 08:13:41 PM
by brisner
Last post November 13, 2019, 10:00:23 AM
