Author Topic: display label orientation  (Read 5911 times)
Offline chrisfisher
  • Unit(s): Humminbird 898c SI Combo
« on: February 19, 2014, 11:19:20 PM »
Hi,
Does anyone know if its possible to change the orientation of the display labels(mph, depth, gps coords) from the SIDE to the BOTTOM? and the size of them? If so do you know what version this was brought on and where the adjustment setting is? This has been one of the only HUGE downfalls I find with this unit however I am a few versions behind. Thanks for your help
Re: display label orientation
« Reply #1 on: February 20, 2014, 09:15:13 AM »
This has been on the HB wish since the beginning of the 800/900 series units...(probably the most requested wish list item ever)...
The Readouts boxes can be turned off in the full screen SI view only...
Under the Sonar tab..cursor down to "Readouts"...select "Off"...
« Last Edit: February 20, 2014, 09:18:53 AM by rnvinc »
Offline chrisfisher
« Reply #2 on: February 20, 2014, 01:54:09 PM »
Thanks for the reply! I didn't know about the SI readouts. That should at least help a bit.
« Reply #3 on: February 20, 2014, 09:56:43 PM »
It wouldn't hurt to call or email HB with your opinion on more user control of the readout data...
The more people that ask for it...the more likely they are to change it...
Last post March 14, 2010, 05:33:55 PM
by Chiboo
Last post April 09, 2012, 10:11:05 AM
Last post April 12, 2012, 05:56:34 PM
by Emma Clarke
Last post May 31, 2012, 08:59:52 PM
by rookiejd
Last post June 18, 2012, 02:38:38 PM
by gramps50
Last post August 10, 2012, 12:32:36 PM
Last post May 24, 2013, 10:24:51 AM
Last post June 20, 2013, 06:04:16 AM
by marlin23
