Author Topic: NMEA Wire colors 1198 si  (Read 8298 times)
Offline JDGuess
  • Unit(s): 1198c si and Matrix 35
« on: May 27, 2013, 04:53:31 AM »
I  have lost my installation instructions and could not find this any where in the user manual.   Could someone tell me which is in or + and which is - or common on the 1198? Thanks in advance.
        JDGuess?
Re: NMEA Wire colors 1198 si
« Reply #1 on: May 28, 2013, 11:28:14 AM »
Welcome to the Side Imaging Forums JDGuess.
Are you asking about the wire color for the GPS Receiver ‘pigtail’ wires?
If so, which set do you have: Red, White and Black or Green, White and Black?
On both sets, the Black is NMEA Ground and White is the NMEA + or output but so is the Green wire connection (it uses a different prefix on the NMEA sentences though).
Give us some details on what you have and what you are trying to connect to.
Offline JDGuess
« Reply #2 on: May 28, 2013, 12:04:12 PM »
Hey Greg, thanks for the reply.  Yes I was asking about the gps pigtail. I'm connecting to a Simrad AP12 auto pilot. I used this same Pigtail with my   Matrix and AP 12 and it worked perfect. I used the black and white wires. The green was not used.
   I have had no luck with my 1198 connecting to AP.  I guess I should try black and green?
        Thanks, John Guess
« Reply #3 on: May 28, 2013, 12:29:07 PM »
The same White and Black connections should work John.
Make sure that you remembered to turn on the NMEA Output menu in the 1198 unit.
Offline JDGuess
« Reply #4 on: May 28, 2013, 12:45:44 PM »
I had the output turned on. I' ll recheck my connections and try again. Thanks
Offline JDGuess
« Reply #5 on: May 28, 2013, 03:08:19 PM »
BINGO!  Got it Greg. Thanks, sure was missing AP taking me where I wanted to go.   Humminbird to Simrad AP12- White to Red and Black to Blue.
                                  Gone Fishing!
Last post August 13, 2011, 08:28:02 PM
Last post August 16, 2011, 06:26:28 PM
by Roddy
Last post April 15, 2012, 08:52:07 AM
Last post October 09, 2012, 12:03:58 PM
by davefewox
Last post June 28, 2014, 12:18:01 PM
by slabbacks
Last post September 02, 2015, 04:10:47 PM
Last post October 18, 2015, 09:21:29 PM
by larry crouch
Last post September 09, 2018, 07:58:26 AM
