Author Topic: NMEA 0183 IN on 1198  (Read 12543 times)
Offline davefewox
« on: October 08, 2012, 12:40:44 PM »
see plenty of info on NMEA 0183 out via the GPS pigtail, what about IN ? I'd like the 1198c to take heading data from the autopilot for more accurate charting at slow speeds.
Re: NMEA 0183 IN on 1198
« Reply #1 on: October 08, 2012, 02:19:19 PM »
The 1198c Si unit can use the NMEA 0183 output from another device in place of its GPS Receiver.  You will need the As-HHGPS connection cable for this or you will have to sacrifice the connector for the GR50 GPS Receiver you have.
Offline davefewox
« Reply #2 on: October 09, 2012, 09:02:09 AM »
so it either or? can the 1198 process the gps signal and the heading data in at the same time? are there any wiring diagrams? I can easily order that cable and may already have one. thanks
Offline davefewox
« Reply #3 on: October 09, 2012, 09:13:59 AM »
perhaps I found my answer? but will it still read the gaps at the same time:
1. Insert the Handheld GPS Cable’s NMEA-COM connector into the appropriate terminal slot on the back of your Fishing System control head. The slots are keyed to prevent reverse installation, so be careful not to force the connector into the holder. The pinouts of the Humminbird® NMEA data cable are as follows:
• Red Wire: +12V
• Black Wire: Ground
• Green Wire: NMEA In
• White Wire: NMEA Out.
Offline davefewox
« Reply #4 on: October 09, 2012, 09:15:31 AM »
and just to be clear, there are no NMEA in existing in the GPS pigtail?
« Reply #5 on: October 09, 2012, 11:31:56 AM »
Correct, no NMEA data in on the NMEA pigtail wire.
No, the unit will accept one NMEA data input at a time.  If your autopilot does not also output the NMEA position sentences, than the unit will not know where to plot your position on the map.  If all your autopilot outputs is the heading NMEA sentence than I do not think that it will work.
Offline davefewox
« Reply #6 on: October 09, 2012, 12:03:58 PM »
thanks Greg, darn I just ordered the cable
Last post February 28, 2011, 03:30:28 PM
Last post July 04, 2012, 01:57:18 PM
by PaulB
Last post July 22, 2013, 07:54:10 PM
by EZM
Last post July 09, 2014, 03:51:51 PM
by fishesman
Last post March 11, 2015, 07:55:16 PM
Last post June 14, 2017, 09:55:22 AM
by Juicegoose
Last post July 07, 2017, 12:09:11 AM
by jabsy
Last post July 10, 2018, 02:02:23 PM
by Mark Saikaley
