Author Topic: Jack Plate Mounting Transducers  (Read 13555 times)
Offline bbushong
  • Unit(s): 798ci
« on: June 29, 2012, 09:15:57 AM »
I am wanting to mount my transducer on the jack plate of my boat. The boat is a loner boat so I don't want to drill holes in the transom. I was wondering if anyone else has done this and can tell me how it worked out? Any motor interferance? Any turbulance interfererance? I don't really care that I won't get readings at high speeds, I just want to get good readings when idleing around. Any help would be great thanks!
Re: Jack Plate Mounting Transducers
« Reply #1 on: June 29, 2012, 10:31:17 AM »
I think a lot of the Bass boat guys mount their transducers to
the jackplate.
I don't use a jack plate, but you might consider this:
The jackplate depth could change depending on the trim/depth of your motor.
The optimum jackplate depth for your motor, may not be the optimum
jackplate depth for your transducer.
Also, you want the transducer it at least 15 inches away from your prop.
Hopefully somebody that has mounted it this way will post.
« Reply #2 on: June 29, 2012, 10:45:24 AM »
I’ve done jackplate mounts but never on a loaner boat that we couldn’t drill holes in.  The body of the transducer has to be lower than the jackplate and depending on the size of the jackplate and Si transducer used; the transducer may have to be trimmed up to keep from blocking one side of the Si signal.  No turbulence interference unless you are backing up or above a slow trolling speed (no high-speed depth readings).
Offline bbushong
  • Unit(s): 798ci
« Reply #3 on: June 29, 2012, 11:22:41 AM »
It's a manual jackplate so I dont have to worry about the depth of it changing. I just don't want to drill holes in the transom of his boat but he would't mind if I drilled into the jackplate.
Offline Redge
  • Unit(s): 958, 1198
  • Software: 6.68, 6.74
  • Accessories: HS puck
« Reply #4 on: July 01, 2012, 04:38:06 PM »
I mounted mine to the bottom of my fixed jack plate, had no problems and it works perfect!  Skeeter boat.
Offline bbushong
  • Unit(s): 798ci
« Reply #5 on: July 02, 2012, 07:58:46 AM »
I am glad to here this method works well. Thanks for all your input!
Last post January 23, 2011, 06:46:33 AM
by stillbear
Last post January 17, 2012, 06:54:23 PM
by stillbear
Last post May 02, 2012, 10:52:10 PM
Last post July 04, 2012, 03:17:02 PM
by calli1
Last post February 05, 2013, 07:54:30 PM
Last post April 05, 2013, 07:40:40 PM
by raypla
Last post May 20, 2013, 12:38:12 PM
Last post January 01, 2016, 08:30:25 PM
by buell1965
