Author Topic: How to mount inside hull puck  (Read 8298 times)
Offline fishbone
« on: February 06, 2013, 04:43:14 PM »
I'm moving my HB 998 SI to a fiberglass boat. The main transducer will be mounted on a jack plate, with an XP-9-20 transducer on the inside.
Is there a kit, or do I use an epoxy to fit it to the hull?
Also, will the main transducer on the jack plate provide a water temp reading?
thanks, Ron
2013 Stratos 189 VLO
E-Tec 150 HO 150hp, 6" JP
80# Fortrex, 2ea 8' Power Poles
HB 998cSI @ Console, HB 999HD SI @ Bow
Re: How to mount inside hull puck
« Reply #1 on: February 07, 2013, 10:31:16 AM »
Installation instructions come with that XP-9-20 transducer as does an epoxy packet.
Yes, the water temperature will come from the jack plate mounted HDSi transducer but you can also add an additional temperature sensor if you would like to.  The unit will display both temps and has separate alarms for these if you want.  Some use the second temperature sensor to monitor water temp in the livewell.
Offline fishbone
« Reply #2 on: February 07, 2013, 10:48:02 AM »
Thanks. Greg. I have the products on order.
Last post March 13, 2011, 05:47:57 PM
by lolar3288
Last post March 11, 2011, 11:47:15 PM
by reddog
Last post February 18, 2012, 10:49:25 PM
by choc_e
Last post May 22, 2012, 02:06:46 PM
Last post August 18, 2012, 01:22:34 PM
by Roddy
Last post October 30, 2012, 01:51:28 PM
Last post May 20, 2013, 12:38:12 PM
Last post April 14, 2020, 09:51:55 PM
