Author Topic: HumVeiwer: Windows cannot find 'javaw'.  (Read 10314 times)
Offline compressor
  • Unit(s): 898c si HD
  • Accessories: Lakemaster
« on: May 09, 2013, 10:51:49 AM »
I installed the latest Java through the HumViewer link. Running Windows 7 Pro 64 bit. Program gives a "Windows cannot find 'javaw'. Make sure you typed the name correctly, and then try again."
Progam won' run. Searched and did not find a solution.
Anyone have a fix?
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: HumVeiwer: Windows cannot find 'javaw'.
« Reply #1 on: May 10, 2013, 04:35:15 PM »
I run Windows PRO 64-bit also and have had this happen every time I allow a new Java Update.  And I lose the Java Control Panel under Control Panel->Programs.
I just do a Java Runtime download and install, and it is fixed and the Java Control Panel is back again.
Offline compressor
« Reply #2 on: May 10, 2013, 05:55:16 PM »
Thanks, a reinstall of Java and then Humviewer fixed the problem. Make sure to install the 32 bit Java if you are using 32 bit IE9 even though your OS may be 64 bit.
Last post February 06, 2010, 03:14:00 PM
by SIView
Last post February 11, 2010, 02:28:55 PM
by Rocketman783
Last post February 24, 2011, 08:48:38 AM
by Moose1am
Last post July 02, 2012, 10:12:32 AM
by Roddy
Last post October 23, 2012, 06:22:35 AM
by Rickard
Last post September 15, 2014, 02:15:34 PM
by Nitro78
Last post April 02, 2015, 12:56:38 AM
Last post August 11, 2015, 06:21:58 PM
by lancepeterson
