Author Topic: What products can be used to clean my screen/display on my HB unit?  (Read 34733 times)
What products can be used to clean my display?
Humminbird recommends using Windex® Vinegar Multi Surface(in the spray bottle).
Do NOT use any wipes products (which can also be available as the brand name Windex Multi-Task).
The lens contains a special coating which improves visibility.  It is recommend to use the above cleaner because we have tested and proved this cleaner.  It does not deteriorate the coatings on the lens.
Offline justfishin
Hate to bring this up again but I can't find the Windex locally.  Any other alternatives?  Also what type of cloth is everyone using?
James
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
justfishin-- I found the Windex® Vinegar Multi Surface(in the spray bottle) at Walmart.
Just spray a corner of a microfiber cloth, wipe screen, and dry with dry portion of cloth.
Offline FriscoSpices.Com
Does it get rid of the nasty water spot outlines? Also has anyone ever tried the rain x application to keep water from staying on the surface?
Offline riven1950
  • Unit(s): 798ci si
I found the recommended product ...windex / vinegar at walmart this week. Have not tried it yet but they did have it in stock.
Yesm the Windes vinigar  multi-purpose product does remove water spots. rain or calcium.
Have never tried the rain-x stuff.
Offline vmoyers
The Windex® Vinegar Multi Surface is the quick clean solution. However, if you still have water stain spots after using it, grab a microfiber cloth, wet it with warm water and apply a couple of small drops of Dawn® dishwashing liquid to the cloth. Gently wipe the screen clean with the portion of the cloth that you applied the Dawn® to, then warm rinse the cloth, wipe the screen and dry it with a couple of tissue papers. Your spots will be gone  8)
Last post May 30, 2010, 03:04:40 PM
by vmoyers
Last post April 10, 2010, 05:12:18 AM
by keizerh
Last post June 04, 2010, 06:24:32 PM
Last post May 31, 2012, 04:48:14 PM
Last post October 27, 2012, 09:22:46 AM
Last post May 06, 2013, 03:56:01 PM
Last post April 09, 2015, 07:12:06 PM
Last post May 22, 2015, 01:17:41 PM
