Author Topic: Interference between units  (Read 7901 times)
Offline Bassmar
  • Unit(s): 798ci SI ; 898c SI
  • Accessories: Interlink
« on: April 14, 2013, 03:43:52 AM »
I have an 898 on the bow with the transducer on the trolling motor. A 798 unit at the consol with the transducer on the stern. It is a 18 foot bass boat. I have noticed that when both units are running in side scan mode I get interference on the display. I appears as lines running accross the display about a half inch apart. When I shut down one unit the lines dissapear on the other. Is this normal? Can anything be done to minimise or eliminate this?
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Interference between units
« Reply #1 on: April 14, 2013, 07:46:51 AM »
The problem is: When 2 sonar units transmit on the same frequency they will conflict and in effect cause interference with each other.
Offline Bassmar
« Reply #2 on: April 14, 2013, 09:45:10 AM »
So you are saying that the interference is unavoidable? I never have any issues with visble interference when running two or more sounders in traditional mode only when on side scan.
Offline bobcoy
« Reply #3 on: April 14, 2013, 02:55:36 PM »
If your sidescans  parallel it should not be a problem unless something is deflecting the signal back. From your description they are obviously effecting each other. 2D sonar is notorious for doing that as the width of cone shaped scan is usually overlapping and causing that crosstalk that looks like interferrence.
by garinis33
Last post June 10, 2010, 09:46:46 AM
by jimf
Last post April 24, 2011, 11:05:28 AM
by FlatsFokker
Last post June 27, 2011, 01:53:40 PM
Last post July 15, 2011, 09:15:58 PM
by Double Digit
Last post October 30, 2011, 08:53:59 AM
by Mark997
Last post December 11, 2012, 07:22:15 AM
Last post February 08, 2013, 02:12:20 PM
by Ken L
