Author Topic: need help mounting 998c si transducer on skeeter sx-190  (Read 13146 times)
Offline grae46
  • Unit(s): 998c HD SI, 788ci HD DI
« on: December 29, 2013, 10:01:15 PM »
Hi Everyone,
I recently got the 998c si and am having a little trouble figure out the best spot to mount the transducer.  I have looked at tons of other threads but the back of my boat seems to be a little different from the other.  I have put a ribbon across like I have seen other do and know the highest it can go. I'm just worried where I'm thinking will have the motor in the way when its trimmed down.  If you have any thoughts or suggestions I would be interested in hearing them! If there is another angled picture that could more let me know and I can take more.  Thanks
Offline grae46
Re: need help mounting 998c si transducer on skeeter sx-190
« Reply #1 on: December 29, 2013, 10:05:02 PM »
more pictures
Offline grae46
« Reply #2 on: December 29, 2013, 10:06:59 PM »
one more
« Reply #3 on: December 29, 2013, 11:09:59 PM »
Here's some more Skeeter installation ideas...(SL 190 transom looks very similar to yours)...
http://www.bbcboards.net/humminbird-sonar-gps/172973-skeeter-boats-installation-images.html
It's very possible you may have to trim the motor up some when scanning....
« Last Edit: December 29, 2013, 11:11:24 PM by rnvinc »
Offline grae46
« Reply #4 on: December 30, 2013, 05:16:12 PM »
Thanks.  I saw that other forum and was kinda basing it off that when I was looking at spots for mine.  Do you know off hand if that is normally a good spot with getting a clean read(air bubbles) being close to the motor?
« Reply #5 on: December 30, 2013, 10:52:41 PM »
I would suggest temporarily mounting the xducer with high bond double stick tape and try it....
It's unlikely that this spot will work for high speed on plane readings as the xducer will probably be completely out of the water when the boat is on plane...
Your best scanning is going to be at idle speed anyway...
Last post June 27, 2010, 12:04:16 AM
Last post February 02, 2012, 10:25:51 AM
Last post September 11, 2012, 05:01:42 PM
by Slinger
Last post March 12, 2015, 10:26:15 AM
by BrazosRiverTom
Last post April 16, 2016, 10:09:41 PM
by fishnfool
Last post February 08, 2019, 10:21:59 AM
by bassmasterG13
Last post February 17, 2026, 09:50:21 AM
by proskeeterman@comcast.net
